997 : 2004- 71
964 : 1989-1993 6
Boxster : 1997- 21
Cayenne : 2003- 4
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Thu Dec 13, 2018 12:00 pm    Post subject: Gauge Questions ... Reply with quote
Hi all, I’d appreciate thoughts on some queries re the voltmeter and the oil pressure gauge.
Firstly , how accurate are they, and are they ‘buffered’ like the temp gauge?
My pressure gauge doesn’t go above 4.5 bars even at first start (my 993 is always up at 5 to begin with) and it appears to be quite ‘laggy’ compared to the 993 when the engine is warmed up and accelerating hard. Is it looked on as an accurate gauge? As an aside I’ve just replaced the sender.
WRT to the battery gauge, it seems to fluctuate between 12.5 and 14V, it normally drops to 13V under load (AC, lights, wipers etc on) and maybe a bit lower again if the engine is at idle. Is this normal gauge behaviour?
I suspect an alternator change is looming.
Thanks all!
Ex. '99 996 C2 manual coupe.
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Thu Dec 13, 2018 4:52 pm    Post subject: Reply with quote
No, that seems about right ballers, a spot more oil will help keep the pressure up, mine was at the recommended halfway point but would not go over 3 and idled 0.5 hot. Topped oil to Max and now much like yours and much healthier pressure and yes not as whippy up and down as the 993 was.
Volt gauge sounds similar too, only way to check accuracy would be digital voltmeter on the alternator, if it's working and battery not dying then I'd say leave it alone.
Last edited by asterix_the_gaul on Thu Dec 13, 2018 6:29 pm; edited 1 time in total
ballcock
PostPosted: Thu Dec 13, 2018 4:57 pm    Post subject: Reply with quote
Brill, thanks for your reply ..
Mine ideals hot at 1 bar, I thought that was very low! But it’s full as per the gauge..
Was thinking of increasing to 10W50 to see if it’d help.
Your 0.5 bar gives me comfort tho Grin
PostPosted: Thu Dec 13, 2018 8:12 pm    Post subject: Reply with quote
My 2 pennys Smile
Ignition on and the oil gauge should read zero .. anything above that and replace the sender unit .
4.5 bar is correct on a cold engine .. it will drop off as it gets warm .
928 the other day and the needle jammed at max for a few seconds .. the sender was over reading and the gauge wont go higher than 5 bar so it jammed the gauge .
Pretty accurate if it reads zero at the start though ... ie if it reads less than 1bar when hot on idle then i would take that as a fault and want a seperate oil gauge check to confirm it .. in other words i take that seriously .
Dash volt meter .. take it with a pinch of salt .. not that accurate .. a true reading is done via a volt meter on the battery .
Basically ive repeated what Asterix said Very Happy
ballcock
PostPosted: Thu Dec 13, 2018 8:54 pm    Post subject: Reply with quote
Thanks DM (was hoping you’d comment!)
Mine has had the sender just changed, it was just reading max value up to then.
It’s now giving good read outs except showing 1 bar once it’s properly hot. This is too low I think.
I don’t know if changing from 5W40 to 10W50 is going to make a huge difference tho?
PostPosted: Fri Dec 14, 2018 8:31 pm    Post subject: Reply with quote
1 bar is about right .. should be slightly over 1bar to be fair .
We as a garage dont go above 5/40 on these cars .
Please be aware though that you have a seperate warning light for low oil pressure .. that would flicker on a hot idle if there was actually an oil pressure fault .
