997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
beejay993
PostPosted: Wed Dec 12, 2018 8:52 pm    Post subject: PSE “auto shut off” disable Reply with quote
Guys, I’m hoping someone will be able to point me in the right direction for some technical advise on disabling the auto cut off on the PSE system between 30-45ish mph. I seem to recall I have to pull a relay or cut some cables ? I’m hoping there is a solution that allows the PSE valves to stay open through the full rev range and then switch off fully when required from the switch on the dash. Thanks in advance
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Dec 12, 2018 8:56 pm    Post subject: Reply with quote
You need to disconnect the wire which goes to the speedo signal.
Grey wire with pink tracer.
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Thu Dec 13, 2018 1:57 am    Post subject: Reply with quote
There are 3 ways of doing this, all essentially doing the same thing, removing the speed signal, there's the wire cut as MC detailed, the diode cut which is well covered with pictures On this and other forums and the ultimate 2 second job, the terminal bend.
I had only ever heard of the diode cut before..
"Factory instructions and factory fit exhausts included a speed dependent cut out. The relay for the PSE has a terminal fed with the speed signal (Terminal A), remove the relay and carefully bend the terminal 90 degrees so it wont plug into the board and refit the relay. No more speed dependent cut out......
Alternatively, remove the relay board and take out the speed signal wire (the pink one) from the relay plug - takes longer though."
I thought it's revs that trigger the valve opening not speed ? Might have to check that at some length in some tunnels
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Dec 14, 2018 8:23 pm    Post subject: Reply with quote
996 PSE is speed dependent. I think it shuts off between 30 and around 50mph.
Auto shut off easily disabled with the ‘diode snip’. Have a search for a thread by user GT4 if memory serves.
When I did it I snipped one leg of the diode, just in case it ever needed to be reversed.
Also remember to operate the switch a few times each journey or the valves may seize.
beejay993
PostPosted: Sun Dec 16, 2018 12:35 pm    Post subject: Reply with quote
Thanks guys, I’ve carried out a search but I cannot find any type of idiots guide (which I would need 🤣) to pull the relay etc. Does anyone have a link to the best source for this mod ? Thanks in advance
993 C4s - Midnight blue
996 C4s - Arctic
997 Gen 1 Turbo
997 GTS
997 Turbo S - GT Silver
996 C4s - Polar
pzero
PostPosted: Sun Dec 16, 2018 1:05 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?t=66202&postdays=0&postorder=asc&start=0
991.1 Carrera GTS
