997 : 2004- 71
Boxster : 1997- 13
wildej
PostPosted: Wed Dec 12, 2018 1:27 pm    Post subject: Cooling System Fault Reply with quote
Hi Chaps, has anyone had the "Fault Cooling System Visit Repair Shop" warning message pop up on the dash ?
Car seems to be running fine with no coolant loss or temp increase.
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
PostPosted: Wed Dec 12, 2018 7:34 pm    Post subject: Reply with quote
Yup .. seen it many times .. there are about 8 electric valves all run by a single vacumn pipe / system .. if one of the valves fails or looses vacumn then they all fail .
The only fault you as the driver sees is this mesage .
There have been a couple of campaigns / recalls on this fault but that was a few years back..
Either way its a split vacumn pipe or a valve thats leaking .
Original valves were grey .. superceded to another modified grey one which was in turn replaced by a black one .
Garage job im afraid .. doesnt have to be an OPC but if under warrenty then use an OPC .
Indy would find the fault quicker if they use a smoke machine which im pretty sure OPC,s dont have .. at least my last one didnt .
APL911
PostPosted: Thu Dec 13, 2018 8:24 am    Post subject: Reply with quote
I’ve just had this.
3 out of 8 valves failed. One of them was causing my pse to stay open.
Cost me about £430 at Porsche Brooklands.
wildej
PostPosted: Fri Dec 14, 2018 5:35 pm    Post subject: Reply with quote
Thanks for the replies chaps very much appreciated.
Had my Indy look at it today and as stated it’s a couple of the valves on the vacuum system that need replacing Thumb
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
