997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 21
Cayenne : 2003- 4
Milo72
PostPosted: Tue Dec 11, 2018 1:27 pm    Post subject: Good News.... Reply with quote
Being a bad impulsive buyer I bought the car without having its bores checked. I finally had the courage and booked it in and everything is all ok. Seems my chocolate engine isn’t ready to melt just yet...
They did find corroded brake pipes which means an engine drop as it’s the one over the engine Sad not sure if that’s an engine out or just lowered a bit.
997.1 C2S Cab Tip.
kas750
Reims
2006 Porsche 911
PostPosted: Tue Dec 11, 2018 1:32 pm    Post subject: Re: Good News.... Reply with quote
Great news! Thumb
I believe you can avoid an engine drop by putting a joint in the replacement pipe
Milo72
PostPosted: Tue Dec 11, 2018 1:36 pm    Post subject: Reply with quote
I did wonder if there was a cheaper option rather than dropping the engine.
997.1 C2S Cab Tip.
911tom
Watkins Glen
PostPosted: Tue Dec 11, 2018 6:44 pm    Post subject: Reply with quote
The Porsche way is to replace the whole part and that would be the only option at opc. It is a solid lump with no join. However they rarely corrode over the engine as it is dry. I would suggest cutting out the corroded part and joining as Kas750 suggests. Then when you have a real reason to drop the engine in the future replace it with the genuine part.
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
718 Cayman GTS
350Bhp astra van for work, semi-retired from daily duties
2009 Ariel Atom 3 Supercharged SOLD but never forgotten
DucatiRob
PostPosted: Tue Dec 11, 2018 7:02 pm    Post subject: Re: Good News.... Reply with quote
Great news Thumb
Yes I believe if the corroded section is accessible then you can avoid dropping the engine by cutting out the bad section and fitting a new piece of pipe using compression joints, perfectly acceptable solution Thumb
Mercedes CLK DD
Ducati 996
TonyC911
PostPosted: Tue Dec 11, 2018 7:17 pm    Post subject: Reply with quote
GoodJob
I see you are in Bucks Milo72... me too bye
I just wondered which garage you used for your bore-scoping?
Now you can relax for a while and enjoy the ride!
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
Milo72
PostPosted: Tue Dec 11, 2018 7:44 pm    Post subject: Reply with quote
Thank you all... I will suggest the join and see what they say, would rather that if possible. They said they had put a flexible pipe over a gen 2 but there was more space there than in mine with a tip box.
I don’t want to bodge it, but equally if there is a good work around solution significantly cheaper then would be mad not to try it.
Tony... I went to RPM Technik in Cheddington, I have to say they were fantastic. Would recommend them to anyone.
997.1 C2S Cab Tip.
PostPosted: Tue Dec 11, 2018 8:00 pm    Post subject: Reply with quote
There is nothing wrong with a cut and join on brake pipes .. hell ive just done it on my wifes car .. best not to tell her that though Very Happy
It all depends on where the corrosion actually is .. you need a decent straight section of pipe each end of the corrosion to be able to do this .. you also need access and if its above the gearbox then obviously you dont have this .
You cant really just lower an engine on these cars .. maybe 2 inches but thats it .
997 corrosion on brake pipes is a little unusual but i guess they are not getting any younger .. sigh .
Milo72
PostPosted: Tue Dec 11, 2018 8:10 pm    Post subject: Reply with quote
The corrosion was certainly under the underside panel on the passenger side midway along the car... I can’t remeber him showing any further corrosion further back other than on the callipers. Is it a single section of pipe from the O/S rear wheel to that mid point section ?
997.1 C2S Cab Tip.
PostPosted: Tue Dec 11, 2018 9:00 pm    Post subject: Reply with quote
That does sound like a cut / join may well be possible .. without pictures i cant say for sure .. but your garage should be able to say .
There is a connection block in that area .. then its a single pipe to o/s/r and n/s /r
