997 : 2004- 74
Boxster : 1997- 14
Cameltoe & Heel
PostPosted: Mon Dec 10, 2018 11:19 am    Post subject: Condensor Replacement Reply with quote
Chaps, what's the general opinion on condensers?, looking to replace mine which looks marginal so I'm replacing whist access is good, wing removed.
So there seems to be a Hella item on eBay for decent money, is this the one to go for?, there's NRF also, what's opinions out there?.
Trev
Endoman
PostPosted: Mon Dec 10, 2018 7:07 pm    Post subject: Reply with quote
There have been problems with some condensers being slightly too big for the frame. I think they were Hella ones.
I would give Jim @ Chill Out, Leyland a call, 01772 603000. He is a good mate and a fellow 993 owner. He helped me replace the evaporator on mine but will probably swear if you mention it.
I replaced the condenser myself and had the frame etc. powder coated. I'm pretty sure it was a Hella one and it was ok. The rubber mounts were shot and the old condenser just fell apart although it wasn't leaking.
 Filesize:  126.92 KB
 Viewed:  1865 Time(s)
Cameltoe & Heel
PostPosted: Mon Dec 10, 2018 8:54 pm    Post subject: Reply with quote
That's a nice job right there, I've just wire brushed and used smooth hammerite on mine. So the Hella ones you think are good to go?, they seem a reasonable price on the bay sooo.
Trev
mightyvr6
PostPosted: Mon Dec 10, 2018 11:08 pm    Post subject: Reply with quote
I fitted an nrf and was a perfect fit. Think it was hella that was slightly oversize so i went for nrf which definitely fits and cost about £100.
Polar silver c4 varioram
Dream911
PostPosted: Tue Dec 11, 2018 4:45 am    Post subject: Reply with quote
Go for NRF as it defiantly fits. Bought a Hella one 2 years ago and it was more of a forced fit because they are slightly too long. It still did the job but not worth the hassle when the NRF are cheaper anyway.
Cameltoe & Heel
PostPosted: Sun Dec 23, 2018 6:51 pm    Post subject: Reply with quote
Sod it, got a decent discount from OPC so gone for OEM.
Also needed new pipes so ordered too, some seals come with pipes, others I've had to order.
During assembly does anyone know what lube I should use on those seals?.
Trev
Endoman
PostPosted: Sun Dec 23, 2018 8:29 pm    Post subject: Reply with quote
Manual says lubricate seals with the oil used for the compressor.
http://www.denso-am.com/products/automotive-aftermarket/ac-thermal/ac-compressors/practical-tip-on-compressor-oil/
