996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Steve997
PostPosted: Thu Dec 06, 2018 4:41 pm    Post subject: Car Won't Start - Apply Brake Warning Reply with quote
Having a problem starting the car.
Whilst driving I got the ABS amd PASM Failure warning come up and then when I go to start it next time it won't crank at all.
The display says "Apply Brake" which you need to do in the car to start it as its a Tiptronic. Obviously I m pressing the brake pedal but no change and the car is flat with no attempt to crank.
Am I right to think this is most likely just the brake pedal switch failing intermittently and is on its way out????
alex yates
PostPosted: Thu Dec 06, 2018 5:16 pm    Post subject: Reply with quote
Are your brake lights coming on when you put your fut on the brake?
Steve997
PostPosted: Thu Dec 06, 2018 7:15 pm    Post subject: Reply with quote
They flicker on for a second then stay out.
They did this on repeated times. Is the flickering a warning of failure?
jml3p
PostPosted: Fri Dec 07, 2018 11:06 am    Post subject: Reply with quote
Hi
The brake light switch failure on my 996 caused the same issues.
alex yates
PostPosted: Fri Dec 07, 2018 12:36 pm    Post subject: Reply with quote
Brake light switch.
You can probably take it off, strip it down and clean it. I did a thread on it a while ago.
alex yates
PostPosted: Fri Dec 07, 2018 12:38 pm    Post subject: Reply with quote
Here: http://911uk.com/viewtopic.php?t=127602
grbspeedster
PostPosted: Fri Dec 07, 2018 2:20 pm    Post subject: Reply with quote
Same type of issue written up in this months 911 &Porsche world on 996 tip. Replacement part for the 996 is 996 613 103 02 and cost £18 inc vat from Porsche (Euro car parts £22.89 so not always cheaper in aftermarket ) . Might well be same part on 997
Geoff
996 X50 turbo cab
PostPosted: Fri Dec 07, 2018 6:58 pm    Post subject: Reply with quote
The brake switch is actually x2 switches in one , one for the lights and the other for the psm/ car start with a tip.
Unusual to get a non start as it normally just gives a psm fault .. this is because it sees the 2 internal switches working at different times (milli seconds ) .. poor contacts basically .
Either way .. as everyone has said .. it needs a new brake pedal switch .
alex yates
PostPosted: Fri Dec 07, 2018 7:05 pm    Post subject: Reply with quote
......or strip it & clean it for free Smile
Steve997
PostPosted: Sun Dec 09, 2018 9:30 pm    Post subject: Reply with quote
Cheers guys.
Got a new switch fitted and hopefully all sorted now.
Sorry Alex had bought a new switch by time I saw your very helpful thread. Thanks pal
