Boxster : 1997- 14
Cayenne : 2003- 3
cossiemike
PostPosted: Tue Dec 04, 2018 4:58 pm    Post subject: 996 new exhaust system Reply with quote
Hi,I expect my rebuilt engine back before xmas. I plan to replace the whole system. I think the Topgear option with the quieter box seems to be an ideal set up. What do others think? I pl an to replace the manifolds/headers at the same time. I have seen some on ebay for £160/£170. These seem cheap compared to Topgears @ £450. Anybody tried these and what was the quality like? Look forward to some input. Mike.
PostPosted: Tue Dec 04, 2018 5:04 pm    Post subject: Reply with quote
£135:
https://www.ebay.co.uk/itm/STAINLESS-STEEL-EXHAUST-MANIFOLD-FOR-PORSCHE-911-996-3-4-3-6-99-04-NON-TURBO/202409271481
Had them on for 4 years & 40k miles. Nothing wtrong with them. Bit louder than stock too.
Did a couple of reviews here: http://911uk.com/viewtopic.php?t=107741
cossiemike
PostPosted: Tue Dec 04, 2018 5:42 pm    Post subject: 996 manifold Reply with quote
Hi Alex,thought they would be an ok solution. Your link doen't connect now but I have seen similar on ebay. Mike.
Jamie Summers
1992 Porsche 964 RS
PostPosted: Tue Dec 04, 2018 5:53 pm    Post subject: Reply with quote
I recently went for the full Top Gear system from front to back with the mild sport boxes and regular 200 cell cat pipes (rather than x-pipe).
I went with the Top Gear headers purely for convenience and the expectation that they would fit with the rest of the Top Gear system.
It's still early days and I don't think the system has fully bedded in yet (probably only done c.600 miles). It is currently a little boomy at certain revs, but is generally unobtrusive at motorway speed, but definitely throatier under acceleration. It certainly sounds less "911" than previously, and doesn't have the turbine-like howl at the top of the rev range - not good or bad, just different !
I need to put more miles on it and drive in different situations, but for now the jury is out.
I can't knock the quality, price or fitment. It all went on very nicely and looks the part.
'06 Autofarm Cayman RS Development Car
‘99 996 C2
Ex '92 964 RS
Ex '93 968 CS
Ex '90 Clio Mk1 Cup Racer
Ex '90 964 C2
Ex '89 Carrera 3.2
Paynewright
PostPosted: Tue Dec 04, 2018 6:20 pm    Post subject: Reply with quote
Some of the ebay ones have crude 3 into 1 joints that appear to have an overlay metal strip welded on. The better ones have cut and butt welded tubes. PPBB uses ebay ones on his 300k miler.
Ian
PostPosted: Tue Dec 04, 2018 6:46 pm    Post subject: Re: 996 manifold Reply with quote
Sorry Mike, I missed the last digit out. Now updated:
PostPosted: Tue Dec 04, 2018 6:48 pm    Post subject: Reply with quote
......and this is the company who make those Chinese ones:
https://mgpracing.en.alibaba.com/
and the part:
https://mgpracing.en.alibaba.com/product/1929500615-50178420/High_performance_Exhaust_Header_For_P_orsche_996_NONE_TURBO_3_4L_3_6L_99_04_Fits_P_orsche_996_.html?spm=a2700.icbuShop.41413.8.720d63eeNQxhbP
cossiemike
PostPosted: Wed Dec 05, 2018 4:37 pm    Post subject: Re: 996 manifold Reply with quote
Hi Alex,have ordered this set,thanks Mike.
PostPosted: Wed Dec 05, 2018 5:12 pm    Post subject: Reply with quote
thumbsup
GMG
PostPosted: Wed Dec 05, 2018 5:35 pm    Post subject: Reply with quote
...having just spent a weekend removing my exhaust system using combination of blood,sweat , tears an angle grinder and reciprocating saw as a consequence of rust, rust and rust you have my deepest sympathy if you are taking this job on!
I am now replacing every nut and bolt from the manifold back with marine grade stainless steel which won't help me but will relieve the next owner of the misery I experienced Very Happy
cossiemike
PostPosted: Thu Dec 06, 2018 4:13 pm    Post subject: Reply with quote
Hi,my engine is at Hartech for full rebuild and the head studs will be done. I have ordered new system from Topgear today.Mike.
GMG
PostPosted: Thu Dec 06, 2018 7:30 pm    Post subject: Reply with quote
...my head studs were done as we're the silencer brackets it was everything in between! Even though I have had brand new Porsche manifold bolts fitted at £4 each ...I am still going to replace them with marine grade stainless steel ones this weekend....never ever be an issue again...
cossiemike
PostPosted: Sun Dec 09, 2018 10:30 am    Post subject: Reply with quote
New exhaust arrived yeterday,2 days from order. Not bad service.Just need engine back from Hartech.
