996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
steve1
2002 Porsche 996 Carrera 2
PostPosted: Mon Dec 03, 2018 3:59 pm    Post subject: charging Reply with quote
Hi guys
have noticed the volt meter is moving around at tickover, thinking it might
be a loose belt.
Moving between 13 and 14 volts goes up to 14 normal running.
Any other suggestions
also can the diode pack be bought separately or does it mean complete alternator.
thanks in advance.
Steve
2002 996 C2 cab red
Ghianightmare
PostPosted: Mon Dec 03, 2018 6:36 pm    Post subject: Reply with quote
If the belt is loose it means either a pulley is collapsed or tensioner is stuffed, loose belt would make a noise usually.
Voltage regulator is a common issue. Alternator needs to come out to change it. It’s a £25 part for a good non Chinese one.
Alternator not a difficult job, you just need to press out a bush a small bit so it goes back into the frame easily. DONT SMACK IT WITH HAMMER which is suggested on line sometimes.
Plenty of info on here.
2002 Seal Grey C4S
PostPosted: Mon Dec 03, 2018 8:34 pm    Post subject: Reply with quote
Ignore the cluster gauge .. you need a volt meter on the battery to prove there is an issue .
Check the voltage on idle with nothing turned on .. no loads in other words ..
Them do the same check but with all loads turned on .. so main beam , heated seats , hazards etc etc
Full load and it needs to be above 13 volts to prove the alternator / main lead is ok .
Post results if needed .
steve1
PostPosted: Tue Dec 04, 2018 7:07 am    Post subject: Reply with quote
Thanks guys will let you know the results of the check.
2002 996 C2 cab red
