996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Tim996c4
PostPosted: Sun Dec 02, 2018 5:23 pm    Post subject: Torque settings Reply with quote
Does anyone have the torque settings for numbers 7,9,12,13 on the attached diagram?
Thanks in advance....[/img]
 Filesize:  38.18 KB
 Viewed:  1727 Time(s)
Jamesx19
PostPosted: Sun Dec 02, 2018 6:07 pm    Post subject: Reply with quote
From Bentley manual:
7 - 17 ftlbs or 23 nm
9 - Doesn't say
12 - Diagonal brace to body M10 - 48 ftlbs or 65 nm
13 - Diagonal brace to rear cross member M12 - 82 ftlbs or 110 nm
With 9 I'd say take an educated guess based on the above.
1998 C2 Manual
PostPosted: Sun Dec 02, 2018 6:11 pm    Post subject: Reply with quote
Just in case you dont know ..
The workshop manuals can be downloaded here ..
http://911uk.com/viewtopic.php?t=83491
Tim996c4
PostPosted: Sun Dec 02, 2018 6:26 pm    Post subject: Reply with quote
Thanks both. Found the manuals but as you say, 9 doesn't appear to be listed. Any suggestions?
PostPosted: Tue Dec 04, 2018 7:56 pm    Post subject: Reply with quote
Sorry for the late reply ..
Diagonal brace to body M 10x1.5 65 nm / 48 ftlb.
Diagonal brace to cross member M 12x1.5 110 nm / 81 ftlb
Diagonal arm to carrier side section ( collar nut ) M10x1.5 23 nm / 17 ftlb
Thats all that is listed , there is nothing for 9 but you would go with the bolt size for the torque .
Tim996c4
PostPosted: Tue Dec 04, 2018 9:02 pm    Post subject: Reply with quote
Cheers demort. 9 and 12 are the same part number, so I guess the same torque value will be about right....
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Dec 05, 2018 7:40 am    Post subject: Reply with quote
Yes they are the same.
9 is Cross member at front to carrier side section.
12 is diagonal brace to body.
Both 65Nm according to the workshop manual I have.
Tim996c4
PostPosted: Wed Dec 05, 2018 8:46 pm    Post subject: Reply with quote
Thanks MC. Wish they'd use the same names in the manual as they do for parts!
Hatchetf15
PostPosted: Thu Dec 06, 2018 1:41 pm    Post subject: Reply with quote
The Knowledge Gruppe book (p121) also says 65 Nm, as MisterCorn pointed out.
‘02 3.8L 996 C2; ‘06 955 TTS
SDJC
PostPosted: Thu Jan 03, 2019 8:12 am    Post subject: exhaust manifold - K nut torque setting Reply with quote
I have the PPBB titanium stud kit about to be fitted to my 996 Carrera.
I have found the torque setting for the standard bolts is 26Nm (19 ft/lb).
When using K nuts as supplied with the kit what torque setting should I use?
996.2 C2 Meridian Silver.
