996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 12:28 pm    Post subject: Installing Hertz DCX 100.3 speakers in the dash Reply with quote
I wanted a bit more clarity and a lot more oomph from my stereo - my old ears are struggling to hear the finer points of dialogue in The Archers when I have the roof down and a good B road to charge down.
The Hertz speakers I am using were recommended in the speaker thread, I've not yet listened to them but hope that they are good.
With that said, I suspect this method will work with any comparable speaker.
The stock speakers are Nokia/Haes 4ohm, and are fairly "built to a price", to my eye at least.
The speaker is attached with three screws, two pictured here:
And a single one at the opposite side here:
Potentially a thousand plagues lurks in this speaker mesh:
The accused:
Note the three attachment points:
There's an interesting cut-out here, by the single attachment point, which gave me an idea (more on which shortly):
This is the new unit:
I cut away the speaker from the retaining ring:
I then cut three further cut-outs in the retaining ring, spacing them equidistant from one another, meaning that there were then four cut-outs, which meant that the new speaker could drop in and be held firmly:
It's not going to fit into the grill with those tabs, so they need to be edited:
Then simply refit the retaining ring with its new passenger:
This screw barely bites into the metal tab which retains it, I'll use a longer screw if I can find one:
Old and new:
My next task is to teach myself basic CAD and create a digital version of this ring that can be run off using a 3D printer, as I have more of these to do and I don't want to have to cut up a speaker each time.
Halcyon
PostPosted: Sun Dec 02, 2018 4:32 pm    Post subject: Reply with quote
I just cut up all four speakers when i did mine (Alpine, in my case)
But good work fella!! Thumb
996.2 Carrera 4 Convertible Tip
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 5:14 pm    Post subject: Reply with quote
There's an argument for doing that - I've got no use for the old speakers, and they'll likely all go in the bin as I suspect selling them would not be worth the return.
Cutting the retaining rings out would therefore be getting the most use from them.
However, I'd quite like to learn Fusion 360, and play with a 3D printer, so this is a decent excuse.
Jamesx19
PostPosted: Sun Dec 02, 2018 5:18 pm    Post subject: Reply with quote
Nice work Dammit. And great post with all the pics. I can see what my next project is going to be...
1998 C2 Manual
Halcyon
PostPosted: Sun Dec 02, 2018 5:58 pm    Post subject: Reply with quote
Dammit wrote:
....However, I'd quite like to learn Fusion 360, and play with a 3D printer, so this is a decent excuse.
Well, if i had a 3D printer and stuff, I might have done it a different way too! Grin Very Happy
Marky911
Watkins Glen
PostPosted: Sun Dec 02, 2018 6:08 pm    Post subject: Reply with quote
Nice work Neil. Cool
You can get speaker blanks that fit into the grilles exactly the same as the old speakers did. You can then cut them and fit new speakers to those.
Part number - 996.645.049.02.01C £19 each. That's a bit rich though but typical Porsche. If you can make some cheaper then that's good. Thumb
They're the exact speakers I'm going for in the new year. I'm hoping they'll be enough of an upgrade but if not I'll add a powered amp in the front or rear footwell.
I'd rather not as its extra weight and I'm usually too busy driving to listen to music. Road trip with the wife necessitates better sounds though.
Looking forward to your verdict.
sp1ke
PostPosted: Sun Dec 02, 2018 9:29 pm    Post subject: Reply with quote
Nice Job thumbsup
Here's a very similar video walkthrough someone else has made to show how to up cycle an old set of 986/996 speakers to make adaptors for a replacement set
https://www.youtube.com/watch?v=W0LPyCoq5k8
Ghianightmare
PostPosted: Sun Dec 02, 2018 10:34 pm    Post subject: Reply with quote
Nice job and write up Dammit
Just one thing I’m not sure about after reading this and the other speaker threads - can I use these in my car which has the full Bose factory kit?
I’m 99% I can but don’t want to order them until I’m 100%. Wife wants to know what I want for a Christmas...
2002 Seal Grey C4S
Ghianightmare
PostPosted: Sun Dec 02, 2018 11:02 pm    Post subject: Reply with quote
2002 Seal Grey C4S
Dammit
Watkins Glen
PostPosted: Mon Dec 03, 2018 9:51 am    Post subject: Reply with quote
sp1ke wrote:
Nice Job thumbsup
I had watched that one, I thought it made sense, just wanted it to be a little neater and with greater retention of the speaker - that chap uses glue, whereas if you cut out bits of the retaining ring for the ears on the speaker it holds it firmly in place with no requirement for a bonding agent.
Dammit
Watkins Glen
PostPosted: Mon Dec 03, 2018 9:52 am    Post subject: Reply with quote
I believe that you can - hopefully someone else will weigh in, but my understanding is that the MOST fibre optic stuff is between the HU and the amp/s, with the speakers all fed via standard metal wire.
A quick test would be to unscrew one of your speakers and see what it is, of course.
Ghianightmare
PostPosted: Mon Dec 03, 2018 10:09 am    Post subject: Reply with quote
Thanks. I’m PCM 1 so pre MOST I believe. Speakers ordered
2002 Seal Grey C4S
stewhp
PostPosted: Tue Dec 04, 2018 6:51 am    Post subject: Reply with quote
I believe that the Bose speakers are a lower impedence than your normal 4 Ohm versions.
Think they are only 2 Ohm. They should be marked when you take them out.
Current car: 996 Carrera 4S, Carrara white
Previous cars:964 Carrera 4, 964 Carrera2
964 Turbo 3.6
Ghianightmare
PostPosted: Tue Dec 04, 2018 10:13 pm    Post subject: Reply with quote
Oh crap... now I have 4 speakers on the way Confused
2002 Seal Grey C4S
Dammit
Watkins Glen
PostPosted: Tue Dec 04, 2018 10:24 pm    Post subject: Reply with quote
Get a Torx driver and pull one put, it's marked quite clearly on the base of the magnet.
If it's indeed the case that Bose/MOST systems are 2 ohms for all the speakers then I'll happily buy a pair of 100.3's off you, and I imagine someone else will take the others - then you can buy a set that will work (if they are available).
Ghianightmare
PostPosted: Tue Dec 04, 2018 11:21 pm    Post subject: Reply with quote
Thanks Dammit - I had a look at a US supplier site - Crutchfield - and all of the speakers the offer for 2002 Bose are 4 ohm, so all is good.
Too cold and wet outside to go near the car. I’ll drive it to work on Friday and pop one out in the nice warm underground car park
Worst case is the6 won’t be a loud, but as you are aware, anything is better than the originals...
Thanks again. Very Happy
2002 Seal Grey C4S
maldren
PostPosted: Wed Dec 05, 2018 8:50 am    Post subject: Reply with quote
Hi Neil,
have you listened to the new speakers with the old amp? Do they sound significantly different/better?
I'm looking to upgrade my system but I have the MOST system, you're right of course, the fibre part is between the radio and amp and I'll probably fit a new head unit as well. I'm less worried about it looking original so I'm thinking of following Alex's lead.
Mike
Dammit
Watkins Glen
PostPosted: Wed Dec 05, 2018 9:28 am    Post subject: Reply with quote
Not yet- I've got 10 days of holiday to use up this month or I lose it, so I'm off every Friday, and then the last two weeks - so my plan was to do some work on the car on Friday.
You'd be welcome to pop over and give it a listen if you wanted.
maldren
PostPosted: Wed Dec 05, 2018 10:23 am    Post subject: Reply with quote
PM sent
Mike
Marky911
Watkins Glen
PostPosted: Wed Dec 05, 2018 11:06 pm    Post subject: Reply with quote
Yes, please report back on the difference without any other mods Neil.
As I've said I'm hoping to just get away with replacing my 4x 4 inch speakers with the hertz ones and leaving things there. I like the factory look of my CDR-22 as well so that's all that's powering them.
I don't have any door speakers. Simply the 2 dash and 2 rear quarter ones.
I'm not expecting massive improvements but as long as we can hear the music ok, that'll do. Thumb
