996 : 1997-2005 33
Boxster : 1997- 18
Cayman : 2005- 17
roboxm3
PostPosted: Fri Nov 30, 2018 5:16 pm    Post subject: Tired Battery? Reply with quote
Evening All,
A couple of weeks ago my car and my key seemed not to be the best of friends anymore and it started to take 2 or 3 pushes of the button to open the car.
I replaced the battery in the key, thinking that it was the most likely / easiest / cheapest starting point but the problem has gradually got worse and now I’m left to use the key in the door, like the good old days.
Tonight when I got in from work, I noticed that the spoiler had stayed up and I had to switch the ignition back on and lower the spoiler on the button.
Could the above be symptoms off a tired / dying battery?
I checked under the passenger seat and it’s bone dry under there, so hopefully it’s just something simple...hopefully...
Magic919
PostPosted: Fri Nov 30, 2018 5:24 pm    Post subject: Reply with quote
The spoiler would lower as you drive, so not likely to be related to car battery condition
997.2 C4S PDK
The return of Marty Wild
PostPosted: Fri Nov 30, 2018 8:31 pm    Post subject: Reply with quote
Get a Ctek conditioner, that should be able to bring the batt back from almost any state.
Cayman S 987.1
PostPosted: Fri Nov 30, 2018 8:35 pm    Post subject: Reply with quote
How is the engine/starter cranking? If the batt is dying it will be difficult fur the car to turn the engine over and start.
Cayman S 987.1
PostPosted: Fri Nov 30, 2018 9:05 pm    Post subject: Reply with quote
Do me a favour .. pull the carpet on the n/s/r ( so behind the seat at the back of the flat carpet ).. check for water ingress . are the carpets wet basically.
If so does it reach the control unit under the passengers seat .
roboxm3
PostPosted: Fri Nov 30, 2018 11:36 pm    Post subject: Reply with quote
The engine fires into life without hesitation and the carpet behind the passenger seat is bone dry but I haven’t lifted it to check underneath...I’ll do that in the morning.
I know that the spoiler is supposed to rise / lower at 50mph but I didn’t know if the spoiler misbehaving was perhaps one of those Boxster quirks.
ETA; it’s a daily driver, approx. 20mi each way to and from work, so I wouldn’t have though charging should be an issue!?
roboxm3
PostPosted: Sat Dec 08, 2018 9:35 pm    Post subject: Reply with quote
Quick update; I finally got around to digging out and trying the spare key and it works fine, so it’s the key that’s buggered... I’m hoping I can find someone to fix it as opposed to getting a new one, so any recommendations welcome.
The spoiler hasn’t stayed up again after that first and only occasion, so I’ll just assume it was in a funny mood that day...
I double checked the carpets behind / under the seats and all bone dry.
PostPosted: Sun Dec 09, 2018 8:01 pm    Post subject: Reply with quote
It seems to be fixed so thats good .. my only concern is the raised spoiler .. that only happens with a flat battery or water ingress to an alarm cu (under the passenger seat )
For now see how it goes .. hopefully there will be no further problems .. but as a Mechanic im a little .. erm .. unsure atm as the spoiler doesnt fit with the type of problem i would expect from a faulty key remote .
People here do recomend the guys in this link .. ive never used them so cant say ..
http://911uk.com/viewtopic.php?t=130946
Magic919
PostPosted: Sun Dec 09, 2018 8:59 pm    Post subject: Reply with quote
I’ve caught the spoiler button once or twice reaching for keys in the cubbyhole below.
997.2 C4S PDK
roboxm3
PostPosted: Tue Dec 11, 2018 9:03 am    Post subject: Reply with quote
The plot thickens...
Yesterday I tried the 'battery in backwards' reset procedure...which didn't work... Then I tried the 'hold the button whilst turning the key in the door' procedure and for the rest of yesterday evening, I had working remote central locking again...but this morning I don't Grin
I'm thinking I might just have to stump up for a new key at some point...maybe Santa will bring me one...
