996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
CB911
PostPosted: Fri Nov 30, 2018 1:55 pm    Post subject: Replacement OEM engine mounts - suggestions please Reply with quote
Hi all,
I am looking to replace the original engine mounts on my 98, C2, after 20 years and nearly 70k miles they have seen better days. I am also getting a shaking passenger seat at idle.
I have done some research into aftermarket semi-solid options etc, but have decided to keep it OEM. I know genuine Porsche supplied mounts aren’t cheap, so I have been looking for a good quality OEM equivalent. I see Design 911 sell an ‘aftermarket brand’ a pair is £309.00 inc. VAT & delivery.
Any pointers about where to look for cheaper options whilst still getting a decent brand? I am keen to avoid cheap and poor quality aftermarket options, but equally I want to ensure I get best value.
I will also start a thread to properly introduce myself and my car.
Many thanks.
98 996 C2 Manual
peterg1955
PostPosted: Fri Nov 30, 2018 1:57 pm    Post subject: Reply with quote
Type911 do a set that have received good reviews for people on here who have fitted them and very reasonably priced too Wink
https://type911shop.co.uk/epages/de867ca1-377e-432e-84fd-bdccf2206766.sf/en_GB/?ObjectPath=/Shops/de867ca1-377e-432e-84fd-bdccf2206766/Products/9792
2002 996 C2 black/black with aerokit and M030
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Nov 30, 2018 2:16 pm    Post subject: Reply with quote
I understand Hartech sell reconditioned OE ones. I feel drawn to the RSS ones as they are shiny and offer something different, but a bit concerned about buzz in the cabin.
On my list for the winter months... I've watched a few YouTube videos and it looks straightforward. What could possibly go wrong Surprised PC
Good advice I read is to soak the bolts in penetrating oil some time before getting started, and undo both underside bolts a bit before bothering to start on the airbox etc to access the bolts in the engine bay, just in case you fall at the first hurdle!
CB911
Thanks for the suggestion, I will do some more research. I have looked at the RS option, but wasn't sure whether they would be too firm?
Type 911 also appear to sell an OEM equivalent standard mount, with VAT and delivery they are slightly less than Design911 option.
98 996 C2 Manual
CB911
PostPosted: Fri Nov 30, 2018 2:18 pm    Post subject: Reply with quote
Cheers - I am also tempted to try and DIY mine... was planning a YouTube binge tonight to see how easy it is... famous last words!
98 996 C2 Manual
Robertb
PostPosted: Fri Nov 30, 2018 2:46 pm    Post subject: Reply with quote
It looks like a satisfying and reasonably easy DIY.
This was a good video... for us mortals without fancy ramps.
https://www.youtube.com/watch?v=xasJfUrj7EE
And this one as he's very thorough, and shows various pitfalls, inc damaging a clip holding a wire in when dropping the engine. Also has torque settings.
https://www.youtube.com/watch?v=FihC3q8jEhY
Good tip too to tape over the air intake when the airbox removed... knowing my luck I'd drop a bolt down there!
My main worry is what happens if the engine tilts over slightly when the bolts are undone. I'm guessing you need a couple of jacks to hand.
Rincewind
PostPosted: Fri Nov 30, 2018 3:12 pm    Post subject: Reply with quote
I did mine a few weeks ago, I used the non-OE RS mounts from Type911. Took about 45 minutes and could easily be done quicker second time around.
Definitely use the penetrating spray before you start the whole job, you can then grab a cup of tea.
Make sure you have a socket extension of the right length to clear the rear bumper (but not hit the ground) and a good length breaker bar. I made sure both sides had 'cracked' before jacking up the engine, didn't want to get halfway through and find I could only do one side.
You can tell you have jacked the engine up enough because a) the exhaust tips move up closer to the bumper and b) the tips don't drop as you undo the nut.
I did one side at a time so that it was always at least partially attached (not sure if would have made any difference if the jack had let go!
It really was easy once the nuts had started to move. The only annoying thing for me was realising that the exhaust tips must have been adjusted at some point after there was already some droop (maybe when PSE boxes were retrofitted). So, when I got everything tightened up I still had wonky tips - a job for another weekend!
Really pleased with the change to the car handling, a touch more NVH coming through into the car, although most of that has gone now that I have sorted out a few rattles that made themselves more obvious/buzzy! Also think it may have improved with a few miles (or of course my ears are now immune to it!).
searider
PostPosted: Fri Nov 30, 2018 3:13 pm    Post subject: Reply with quote
I got mine from Rockauto:
https://www.rockauto.com/en/catalog/porsche,1999,911,3.4l+h6,1357185,engine,motor+mount,5552
There will be 20% VAT and a royal mail handling charge of £12 to add to those prices.
Usual progression - 205 1.9 / Corrado VR6 / Audi B5 S4 / RS4 / 996 C2 Coupe.
Grey996
PostPosted: Fri Nov 30, 2018 3:40 pm    Post subject: Reply with quote
Did mine last weekend using Rein ones. Easy job, cheapest I found was US Amazon
https://www.amazon.com/gp/product/B00K2OV0MG/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1&tag=vglnkc3993-20
2002 Porsche 996 C2
Robertb
PostPosted: Fri Nov 30, 2018 4:08 pm    Post subject: Reply with quote
How does it work if you buy something imported from the US via US Amazon... does it get held at Customs til you pay the duty and VAT? Is it a faff?
Grey996
PostPosted: Fri Nov 30, 2018 5:21 pm    Post subject: Reply with quote
With Amazon you pay the duty up front so no customs surprises. With postage and customs fees they were still the cheapest.
2002 Porsche 996 C2
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Fri Nov 30, 2018 6:12 pm    Post subject: Reply with quote
I'd check OPC prices first before going aftermarket, esp. If your concerned about nhv.
crash7
PostPosted: Fri Nov 30, 2018 7:42 pm    Post subject: Reply with quote
Original Porsche RS mounts are excellent, firm but not overly firm and easy to fit.
Standard 996 mounts are a 993 part, the RS mounts were fitted to the 993RS and many of the aftermarket items, RSS as an example, are based on the Porsche items.
Ghianightmare
PostPosted: Fri Nov 30, 2018 9:45 pm    Post subject: Reply with quote
The Rein versions are re-boxed OEM and made in Czech Republic. I installed them last month. Search my post. No NVH issues.
2002 Seal Grey C4S
Marky911
Watkins Glen
PostPosted: Fri Nov 30, 2018 9:55 pm    Post subject: Reply with quote
Another Rein user here.
I hate unwanted noise and buzzing so why try and reinvent the wheel.
Just my 2p though and I appreciate some lads track theirs. Thumb
GMG
PostPosted: Sat Dec 01, 2018 6:30 am    Post subject: Reply with quote
...another RockAuto Rein OEM user...I don't want any extra noise or vibration thank you...
CB911
PostPosted: Mon Dec 03, 2018 7:57 pm    Post subject: Reply with quote
Cheers for all the suggestions, may well give the Rein option a go.
Will let you know how I get on.
98 996 C2 Manual
Nduli
PostPosted: Tue Dec 04, 2018 10:04 pm    Post subject: Reply with quote
Daft question but with the link you sent is that $98 per mount ? So bill was $196 + duties?
