996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Milo72
PostPosted: Wed Nov 28, 2018 7:28 pm    Post subject: Damp patch on garage floor... Reply with quote
I have been having a drop in coolant recently and checked all the pipes I could see in the arches and around tank, which were all dry.
I moved the car into the garage for the first time this weekend and have gone out this evening and seen a damp patch on the floor, not a huge amount, maybe a 1/4 of a cup. I know it’s coolant as I can see a pink drip hanging off a bolt head.
My question is are these pipes easy to replace or is this one of the engine out ones I’ve heard about.
For reference I took this picture of the Internet with a rough idea of where it’s coming from.
997.1 C2S Cab Tip.
 Filesize:  1.16 MB
 Viewed:  738 Time(s)
PostPosted: Wed Nov 28, 2018 7:48 pm    Post subject: Reply with quote
Theres a few pipes in that area .. it depends if its the rubber one or the over the engine one .. lets just say i hope its the rubber one .
Need a picture of your actual car / pipes to be sure im afraid .
Milo72
PostPosted: Wed Nov 28, 2018 7:50 pm    Post subject: Reply with quote
Thanks deMort... can you see fairly easily up there if the panel comes off?
997.1 C2S Cab Tip.
PostPosted: Wed Nov 28, 2018 8:11 pm    Post subject: Reply with quote
You can on a ramp .. not as easy on the floor but you are looking for either water .. and you dont often see this .. or you look for white crystals .. a crust of white material on a pipe and pink bits .. be it crystals or again a crust.
Modern antifreeze seals small leaks and this is whats left as it trys to seal the leak .
There is a large ally pipe next to the chassis .. this is the over engine pipe so hopefully its not from that.
A member here did a cut and join though so its not always going to be an engine drop if it is that .. i just say what i think though .. good or bad .. but lets face it .. its normally bad .. i am the bearer of bad news im afraid !
Sometimes i feel like the boogy man Sad
GMG
PostPosted: Wed Nov 28, 2018 8:18 pm    Post subject: Reply with quote
...Ian the Dance Twist Dance Twist Dance Twist Dance Twist man...
Milo72
PostPosted: Wed Nov 28, 2018 8:20 pm    Post subject: Reply with quote
Many Thanks... going to take it to my village garage and see if I can borrow the ramp and have a look.
I will cross my fingers and hope for a rubber pipe issue, but it is what it is.... the joys and expense of Porsche ownership.
997.1 C2S Cab Tip.
PostPosted: Wed Nov 28, 2018 8:29 pm    Post subject: Reply with quote
The cut and join i read about on here seemed pretty good .. im afraid i dont remember the post about it but it is an option .
Boogy man .. Floor excellent !
Milo72
PostPosted: Wed Nov 28, 2018 8:34 pm    Post subject: Reply with quote
Thanks Boogy Man...what’s the rough cost if it is the pipe over the top... ?
997.1 C2S Cab Tip.
PostPosted: Wed Nov 28, 2018 8:40 pm    Post subject: Reply with quote
A manual engine drop and reinstall is about 8 hrs labour .. for a tip its about 12 hrs labour .. you then have the parts on top and about 1 hour extra to fit the pipe .. im afraid to get an acurate price you need to phone a garage .. i just fix the cars Smile
Labour rate varies from garage to garage but we are £85 plus vat per hour .. OPC and we are talking £150 ish plus vat depending on where in the country you are .
Im deep South though .. not the cheapest !
Milo72
PostPosted: Wed Nov 28, 2018 9:14 pm    Post subject: Reply with quote
Ouch.... let’s hope it’s a clip on a rubber hose then Surprised
997.1 C2S Cab Tip.
