996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Milo72
PostPosted: Tue Nov 27, 2018 10:23 pm    Post subject: 997.1 front splitter Reply with quote
Anyone got any recommendations for a ‘subtle’ splitter?
997.1 C2S Cab Tip.
systech1
PostPosted: Wed Nov 28, 2018 3:46 am    Post subject: Re: 997.1 front splitter Reply with quote
I have installed the standard 991 splitter on my 997.2 using an adaptor kit made by a guy in the US. Install is easy, looks suitably subtle and overall cost reasonable.
He has now produced an adaptor kit for the 997.1 and you can get details here ...https://rennlist.com/forums/997-forum/1112698-991-sports-lip-spoiler-adapter-for-997-1-done.html
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, Carrera Sports wheels, Sport Design steering wheel etc.)
 Filesize:  158.04 KB
 Viewed:  1163 Time(s)
Thefinn
PostPosted: Wed Nov 28, 2018 5:08 pm    Post subject: Reply with quote
I had a Rinspeed one on my old 997.1 there is someone selling them on ebay for quite a cheap price
997.1 C4S CAB
 Filesize:  640.52 KB
 Viewed:  1079 Time(s)
Thefinn
PostPosted: Wed Nov 28, 2018 5:11 pm    Post subject: Reply with quote
I also spotted this the other day but don't know about pricing or if anyone has fitted one yet
997.1 C4S CAB
 Filesize:  612.82 KB
 Viewed:  1074 Time(s)
hermes
PostPosted: Wed Nov 28, 2018 5:49 pm    Post subject: Reply with quote
How about this one?
https://www.maxtondesign.co.uk/body-kits/porsche/porsche-911-997/front-splitter-porsche-911-carrera-997-1-2004-2009
SJD
PostPosted: Wed Nov 28, 2018 7:28 pm    Post subject: Reply with quote
I like the Rinspeed. Is it advertised as such on eBay?
Thefinn
PostPosted: Wed Nov 28, 2018 8:42 pm    Post subject: Reply with quote
https://www.ebay.co.uk/itm/PORSCHE-911-997-FRONT-SPLITTER-BUMPER-LIP-SPOILER/202134273028?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D7fb4ad861fd24def96515733ae7a2033%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D202134273028%26itm%3D202134273028&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A8b3270ef-f34d-11e8-a477-74dbd180e37f%7Cparentrq%3A5c0b41741670aadcfde72ddcfffdf92b%7Ciid%3A1
Try this. I am not sure on the quality as it is differnt to the one I had but it looks to be made if fibreglass. I never got round to painting mine but if you Google 997 Rinspeed front lip you will see what they look like painted as it brings out the indents more, on a black car when painted it looks the mutts.
997.1 C4S CAB
Lordjimimac
PostPosted: Wed Nov 28, 2018 11:31 pm    Post subject: Reply with quote
Hi TheFinn that lip spoiler really looks awesome on your car and at that price I’m seriously considering the Rinspeed- thanks a lot for making me aware of it!
Can I ask what you used to fit it? Did you screw directly into the underside of the bumper? Or did you need bolts? Maybe 3m tape around the sides? Any info you could share on that would give me the confidence to give it a go I think (as the ebay listing states no fixings or instructions are provided).
Big thanks?
997.1 C4S (Atlas grey, black) - current
E92 M3 DCT Comp pack (space grey, black)
E90 M3 6MT (Silverstone II, palladium)
996TT (artic silver, metropole)
E39 m540i (Titan silver, black)
987S (Lapis, metropole)
Z4M coupe (blue, cream)
S2000 (red, black)
Mini Cooper S Works (blue, black)
Alfa 145 Cloverleaf (red, black)
NLW73
PostPosted: Thu Nov 29, 2018 10:24 am    Post subject: Reply with quote
Seconded on that rinspeed one. I have placed the order
Subtle but have always thought the 997.1 needs a little sth up front
997 C2s Schwarz
Thefinn
PostPosted: Thu Nov 29, 2018 8:10 pm    Post subject: Reply with quote
[quote="Lordjimimac"]Hi TheFinn that lip spoiler really looks awesome on your car and at that price I’m seriously considering the Rinspeed- thanks a lot for making me aware of it!
Can I ask what you used to fit it? Did you screw directly into the underside of the bumper? Or did you need bolts? Maybe 3m tape around the sides? Any info you could share on that would give me the confidence to give it a go I think (as the ebay listing states no fixings or instructions.
You have answered the question really as I just screwed it to the underside of the existing bumper with some large headed car body panel screws but a bit of tape on the sides wouldn't hurt. First up I found the centre of the existing bumper and then the lip and marked both with masking tape then fitted from the middle out to make sure all lined up exact as I went along fixing it. I did also have to remove the two small Matt black plastic parts on the bottom ends of the bumper that clip in, this was so that the lip fitted tighter on the ends.
One of the returns came up a little short by about 5mm as it turns into the arch so I partially cut it and built back up the fiberglass to make up the gap.
I am making it sound difficult but it wasn't and if you wanted I am sure you can just offer it up starting with the returns into the arch on each end and if the front looks good you could just fix it where it is. The only reason i did it they way i did is to make sure everything was exactly central and all edges lined perfectly as i am a bit ocd like that but you might not need to if this eBay lip has a better fit.
Once screwed up it was solid but I was going to find some plastic nuts to screw onto the back of the panel screws inside the bumper to make sure after I had it painted, unfortunately before I got to that stage my car had a little kiss with a bit of Armco on the A13 so a bit more than paint was needed I.e. a new front end so that car and I parted. But even with just the screws as said it was solid and I tested it to quite high speeds with no movement what so ever.
All in the job is quite easy and YouTube is your friend, I will also try to find some photos of how I did it but I am not sure I have them anymore but I would say go for it, it's not a tough job that only takes a few hours.
This was the photo that sold it for me when I was looking for a subtle lip a couple of years ago but it doesn't seem to come up on Google anymore so here it is as it make the lip look amazing and not Jimmy Hill at all. Thumb
997.1 C4S CAB
 Filesize:  432.82 KB
 Viewed:  854 Time(s)
NLW73
PostPosted: Thu Nov 29, 2018 11:01 pm    Post subject: Reply with quote
that does look good.
so no extra side skirts? just the front lip?
997 C2s Schwarz
Thefinn
PostPosted: Fri Nov 30, 2018 7:49 am    Post subject: Reply with quote
It doesn't look like it, it's just been lowered
997.1 C4S CAB
Lordjimimac
PostPosted: Fri Nov 30, 2018 11:23 am    Post subject: Reply with quote
Excellent - thanks loads for taking the time to share this!
I researched the 991 adaptor, and the chap has used 'Well Nuts' to attach his adapter to the bumper. I was not familiar with these but they look like a great solution for properly and mechanically attaching the lip to the underside of the bumper. You drill 10mm holes, then the well nut gets pushed through, and when the nut is tightened the piece compresses on the back (hidden) side of the bumper. So you can get a nut and bolt like arrangement, with a cushioned contact point, without having to remove the bumper. The image on these parts shows how they work: https://www.amazon.co.uk/Neoprene-Well-Stainless-Steel-Screw/dp/B009ERRCSS
Looking at the tested specs the chap used on the adaptor, I think this is the set that would possibly be optimal to actually use - https://www.ebay.co.uk/itm/Screen-Screws-Well-Nuts-x-8-Black-Aluminium-Suit-Yamaha-YZF-R125-YZF-R6-YZF-R1-/141754921175?ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F710-53481-19255-0%2F1%3Futm_source%3Dtwenga%26utm_param%3DeyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwMzI0NWUyNzAxOGQ0MDkwOWJjYzk0MjA3ZDBjZTJiNiIsImkiOiI0OTA4OTU4NDkyODk5MTY3OTQyIiwidHMiOjE1NDM1MzE0NTMsInYiOjMsInNvIjoxNTAwLCJjIjozNTU2N30%3D%26utm_campaign%3Dtwenga%26utm_medium%3Dcpc%26ff3%3D4%26pub%3D5574631662%26toolid%3D10001%26campid%3D5338243305%26customid%3D03245e27018d40909bcc94207d0ce2b6%26mpre%3Dhttp%253A%252F%252Fwww.ebay.co.uk%252Fitm%252FScreen-Screws-Well-Nuts-x-8-Black-Aluminium-Suit-Yamaha-YZF-R125-YZF-R6-YZF-R1-%252F141754921175%26srcrot%3D710-53481-19255-0%26rvr_id%3D1762761565744%26rvr_ts%3D6456d44c1670a9927957b560fffef9e1&_mwBanner=1&_rdt=1&ul_noapp=true
I think ill use these + some 3M VBH tape and have a go at this. Big thanks all - gotta love this forum!
[quote="Thefinn"]
S2000 (red, black)
