997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
alex yates
PostPosted: Wed Nov 28, 2018 10:21 pm    Post subject: Reply with quote
The issue with the braking is potentially ABS, not PSM. Turning the PSM off does not deactivate the ABS.
If you try and look inside the upright from the inside of the car you may see it. For some reason I'm convinced there's a hole in the upright that you can look down and see the ring but I may be wrong.
If you pull your ABS/PSM fuse out you should be able to drive the car without the issue happening.
Goto page Previous  1, 2
Page 2 of 2
