997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Grey996
PostPosted: Sun Nov 25, 2018 7:08 pm    Post subject: Shifting not as crisp as I'd like. Reply with quote
As above really, especially the lower gears at slower speeds. It will go into gear but it does take a bit of persuasion especially first and up to second and it's not the reassuring clunk of the upper gears. I'm hoping it maybe adjustment in the cables but can anyone advise? I had a look at them at the gearbox end and there doesn't seem excessive play and they're cable tied in place. When I swapped the shifter I marked the cables and fitted them in the same position.
Other relevant work I've done to rule out is new clutch, 997 shifter, engine mounts, gearbox mount inserts.
2002 Porsche 996 C2
Grey996
PostPosted: Sun Nov 25, 2018 8:40 pm    Post subject: Reply with quote
I've found the alignment tool which I've ordered so I'll give that a try.
2002 Porsche 996 C2
Grey996
PostPosted: Sun Nov 25, 2018 9:11 pm    Post subject: Reply with quote
2002 Porsche 996 C2
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Nov 25, 2018 9:23 pm    Post subject: Reply with quote
I doubt that is the issue. If the movement at the lever end is not the limiting factor then the setup is OK.
alex yates
PostPosted: Sun Nov 25, 2018 9:55 pm    Post subject: Reply with quote
Sounds like selector rail inside your gearbox or some other gearbox issue like worn synchros.
NedHan79
PostPosted: Sun Nov 25, 2018 10:08 pm    Post subject: Reply with quote
I wouldn’t be happy with my change either. It’s got some sort of quick shift but I find it a bit woolly. My clutch is a bit on the long side so I’ll not panic about it until I’ve a new clutch but I’m in no hurry for that either. Is there any real adjustment to be had?
Sorry to hijack your thread. It’s I’m possibly looking at the same problem you are
alex yates
PostPosted: Sun Nov 25, 2018 10:14 pm    Post subject: Reply with quote
You need one of my solid bearing short shift kits Grin
http://911uk.com/viewtopic.php?t=127355
Johnd52
2011 Porsche Cayman 987
PostPosted: Sun Nov 25, 2018 10:51 pm    Post subject: Reply with quote
Could it be engine mounts?
2015 Cayman GTS. No more PDK but still red.
Paynewright
PostPosted: Mon Nov 26, 2018 12:25 am    Post subject: Reply with quote
When was the last time the oil was changed?
Always removed the filler plug first to ensure it comes out!
Grey996
PostPosted: Mon Nov 26, 2018 10:38 am    Post subject: Reply with quote
I hope it’s not the actual gear box 🤞
Engine mounts swapped at the weekend, there’s a definite improvement along with the gearbox mount inserts.
Not sure when the oil was last changed, i’ll check.
Ta
2002 Porsche 996 C2
crash7
PostPosted: Mon Nov 26, 2018 1:15 pm    Post subject: Reply with quote
Alex,
Are you able to modify the standard Porsche shift with more robust components?
Or do you only remove the standard shift and replace with your modified short shift?
alex yates
PostPosted: Mon Nov 26, 2018 1:24 pm    Post subject: Reply with quote
I just supply the modified SSK for you to fit.
