964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
mskunert
PostPosted: Sat Nov 24, 2018 11:28 am    Post subject: 986 vibration on tickover Reply with quote
Hi does anybody have any ideas what may cause a slight vibration coming from rear on tickover. Disappears when moving. Possibly slight grinding noise.
One life, live it.
mskunert
PostPosted: Sat Nov 24, 2018 12:02 pm    Post subject: Reply with quote
Had the engine cover off, and it’s heard by the rear bulkhead next to the cam belt ( at least I think it’s the cam belt).
One life, live it.
PostPosted: Sat Nov 24, 2018 6:25 pm    Post subject: Reply with quote
The car doesnt have a cam belt .. timing chains on these and theres one each end of the engine .
I would start by removeing the inspection panel behind the rear seats , remove the drive belt then check the idler pullys .. i would also check the water pump for play as this is the most likely fault from your desription .
A sound clip please or a video if its not the water pump .
mskunert
PostPosted: Sun Nov 25, 2018 8:59 am    Post subject: Reply with quote
I would start by removeing the inspection panel behind the rear seats , remove the drive belt then check the idler pullys .. i would also check the water pump for play as this is the most likely fault.
Thanks I’ll take a look into the water pump.
One life, live it.
kas750
Reims
2006 Porsche 911
PostPosted: Sun Nov 25, 2018 2:01 pm    Post subject: Reply with quote
My car did that and the engine mount bracket had fatigue snapped.
Telltale sign is a lob sided exhaust tail pipe.
