997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
tp81
1997 Porsche 993 Carrera 2S
PostPosted: Thu Mar 21, 2019 3:59 pm    Post subject: Reply with quote
Is there a company name?
1971 Alfa GT 1300 Junior
1973 911E (restoration project)
1995 993 RS
1989 3.2 Targa
2013 110 Defender
2018 Panamera Hybrid
Endoman
PostPosted: Fri Mar 22, 2019 11:44 am    Post subject: Reply with quote
The shop was "Bargain Booze" they don't carry Buckfast either.
Diddi
PostPosted: Sun Mar 31, 2019 10:25 pm    Post subject: Reply with quote
…..I hope it will be better from now on with this delivery service
Grüsse, Diddi
 Filesize:  49.17 KB
 Viewed:  423 Time(s)
9xxnick
PostPosted: Mon Apr 01, 2019 10:58 pm    Post subject: Reply with quote
Hang on a minute - you sent mine by DHL. I hadn't realised there was an option to upgrade... Cool
Diddi
PostPosted: Mon Apr 01, 2019 11:28 pm    Post subject: Reply with quote
….next time Thumb
Grüsse, Diddi
Diddi
PostPosted: Mon Apr 01, 2019 11:30 pm    Post subject: Reply with quote
….DHL next time Thumb
with Hermes, it worked out again.
Grüsse, Diddi
Kat1
PostPosted: Tue Apr 09, 2019 3:53 pm    Post subject: Reply with quote
wilsonny wrote:
thought id be clever over the weekend and lift the car up, put it in gear, then turn the wheels to get the engine to the timing marks so I can remove the distributor. turns out I don't understand very well how differentials work ! (turning one wheel spins the other in the opposite direction and trying to turn both simultaneously was beyond the strength of me and my helper). no way could I get the engine turning in this situation.
presume you guys who have removed the dizz have managed by putting in gear and rolling the car back and forth (while on the ground) ?
1. Lift car on ramp.
2. Release hand brake.
3. Remove right hand rear wheel only.(see below)
4. Slacken handbrake adjuster on this side only.
5 Apply handbrake.
6. Select 5th or 6th gear.
7. Turn hub with the 32 mm driveshaft nut until timing marks align.
I managed to view the timing marks whilst at the same time turning the hub with my foot.
If you are a left footer then remove left hand wheel if you want to make it easy!
Diddi
PostPosted: Tue Apr 09, 2019 5:14 pm    Post subject: Reply with quote
…..why so complicated to jack up etc. simply insert the 3rd gear and push the 11er on Position - first your own woman to push get (later the girlfriend)
Grüsse, Diddi
Diddi
PostPosted: Thu Apr 18, 2019 11:34 am    Post subject: Reply with quote
......….that's how it looks inside
Grüsse, Diddi
 Filesize:  190.19 KB
 Viewed:  64 Time(s)
Goto page Previous  1, 2, 3
Page 3 of 3
