996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
dt4
PostPosted: Wed Nov 21, 2018 5:11 pm    Post subject: Knocking from front offside suspension Reply with quote
I found the anti roll bar boot had split on the top joint so replaced the drop link but still have the knocking
It tends to go away after a few miles of driving but returns each fresh journey
What is the usual cause, top mounts or lower control arm?
cheers
alex yates
PostPosted: Wed Nov 21, 2018 5:35 pm    Post subject: Reply with quote
Anti roll bar bushes. Check you've nothing in your frunk rattling around Grin
dt4
PostPosted: Wed Nov 21, 2018 7:13 pm    Post subject: Reply with quote
I'll give it a going over but I didnt find any play it in the arb when I did the drop link
Dafter things have happened than the suggested stuff rattling around so Ill empty it before the next test drive lol
alex yates
PostPosted: Wed Nov 21, 2018 7:16 pm    Post subject: Reply with quote
I once had a small fire extinguisher in there when I went on holiday. For the first 2 days of my holiday I was panicking something was wrong........until I realised what it was. Embarassed
dt4
PostPosted: Thu Nov 22, 2018 8:44 pm    Post subject: Reply with quote
`I cant see any play in the arb and bushes and cant see anything untoward in the lower arm arm ball joint
With the wheel off the ground and unloaded should the top mount rotate when the nut on top is turned?
PostPosted: Thu Nov 22, 2018 9:16 pm    Post subject: Reply with quote
If the knock is over bumps and sounds kinda like .. bonk .. bonk bonk bonk ..simlilar to a link rod then its the diagonal arms .. roughly 50k miles and these start to knock like this ..
You wont feel anything wiggleing the wheel top to bottom or side to side .. its an annoyance and not a problem as such .
If this noise but far louder then its anti roll bar bushes .
To have a better idea then i really need a sound clip im afraid .
Top mounts wear .. you turn them lock to lock and look at the rubber section (in the arch ) .. you will see if its debonding .. dont cause a noise as such though .. top shock nut loose will though .
dt4
PostPosted: Fri Nov 23, 2018 7:46 am    Post subject: Reply with quote
Thank you
Ill continue to investigate
dt4
PostPosted: Fri Nov 23, 2018 7:16 pm    Post subject: Reply with quote
Actually mine sounds similar in description to this issue
http://911uk.com/viewtopic.php?p=1445111#1445111
PostPosted: Fri Nov 23, 2018 7:18 pm    Post subject: Reply with quote
Erm .. thats a link to this thread ?
dt4
PostPosted: Fri Nov 23, 2018 8:32 pm    Post subject: Reply with quote
Ooops lol
Sorry, http://911uk.com/viewtopic.php?t=131114&highlight=
I'll try and get a sound clip but appreciate its really difficult to diagnose these things from a distance
I suspect it will end up going to the nearest recognised outfit which is Revolution
I was hoping to be able to sort it myself so will keep at it for now
