996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
NedHan79
PostPosted: Wed Nov 21, 2018 9:11 am    Post subject: Lower and wider Reply with quote
What are people’s opinions and experience with lowering springs and wheel spacers? I have an early 3.4 with an aero kit in midnight blue and the gt3 style split rims. I’d like it to sit lower to look more like a gt3 and maybe space the wheels out a little for added effect.
Anyone experience with this and which stuff to use?
PostPosted: Wed Nov 21, 2018 9:27 am    Post subject: Reply with quote
I keyed 996 AND spacers into the 'Search Forum' function and got dozens of threads including this fairly recent one that may be of use to you.
http://911uk.com/viewtopic.php?t=114249&start=0&postdays=0&postorder=asc&highlight=996+spacers
I'm sure others will give you a bespoke reply but reviewing old threads is quicker.
NedHan79
PostPosted: Wed Nov 21, 2018 10:04 am    Post subject: Reply with quote
Great. Thanks
demon
PostPosted: Wed Nov 21, 2018 11:36 am    Post subject: Reply with quote
I went a more OEM route that no-one ever seems to talk about i.e. there was a 5mm factory spacer option applied to the early GT3 cars (as I understand) - hence you can get a set of 4 5mm factory spacers and pair these with the slightly longer (red collared) factory GT3 wheel bolts
5mm is obviously a lot more subtle than the 15-20mm most choose to apply... and the OEM route is a little more costly... but equally there are reasons why wheels are tucked slightly inside the wheel arches...
Lowering a car 10, 20 or 40mm all fits within the ultimate "factory" range - more often it is road condition, sleeping policemen, kerbs and public carparks that determine the best ride height - personally I would be nervous lower than the 20mm drop on my own car - as it sits, my bottom lip scrapes ever so slightly leaving the office car park on my worn down summer tyres, no issues now its wearing its fresher winters....
1998 Carrera - Black, no sunroof, manual, cable throttle, IPD plenum, 200 cell x pipe, Ohlins R&T, LSD, polybushed, Girodisc brakes, custom ("shaved") GT3 RS decklid, 997 sports seats, litronic headlights, RUF mirrors
NedHan79
PostPosted: Wed Nov 21, 2018 11:44 am    Post subject: Reply with quote
Hi demon. I was looking at lowering it 30mm as I seem to have plenty of space in the arches. I was maybe thinking about 7-10mm at the front and 10-15 at the rear. I don’t think 5 would make much difference to the appearance. Do you have any pictures of yours?
demon
PostPosted: Wed Nov 21, 2018 12:41 pm    Post subject: Reply with quote
I'm a terrible source of comparative shots I'm afraid (never consider angles... or figured out how to photograph a black car!)
the following 2 photos maybe give a little comparison though - both are with 5mm front and rear spacers - carpark shot is 20mm lowered, other one is 10mm lowered...
(thumbnails when clicked should open to a full page version)
If you then look at page 13 of coullstar's thread there is an equivalent photo at 30mm lowered...
- each subsequent drop of 10mm below factory standard is surprisingly apparent
http://www.911uk.com/viewtopic.php?t=124107&postdays=0&postorder=asc&start=240
NedHan79
PostPosted: Wed Nov 21, 2018 1:16 pm    Post subject: Reply with quote
I see what you mean about each 10mm making a difference. I like your wheels. Would have been my choice but the ones I have are freshly refurbed so they’ll stay where they are. I’ve always had trouble getting photos on here. Seems to be hit or miss with the ones I can upload.
Think I’ll still go for the 30mm springs though I’m not sure about the spacers
 Filesize:  1.11 MB
 Viewed:  2458 Time(s)
Stotty
PostPosted: Wed Nov 21, 2018 2:14 pm    Post subject: Reply with quote
Mine is non-aero kit, lowered 30mm on H&R springs (Koni shocks), runinng X74 alignment, and I have absolutely no issues with grounding... be that over high speed compressions, or speed humps.
Ideally, I'd have liked it another 10mm lower, but didn't want to spend silly money on decent quality coilovers.
Spacers...
Rear:
Assuming you're on stock et65 10" rears, you have loads of room to play with. I'm running a 15mm spacer (with longer bolts), so et50 equivalent, and there's still loads of room. Without having the rear arches rolled I think I could go another 5-7mm without fouling. Once I've found somewhere that can roll my rear arches, I'll go to c.et35-38.... which would be the equivalent of a 27-30mm spacer with a stock wheel. I know of people running et38 11" rears... though you'd be limited to a 265 tyre on something that extreme (which isn't my style).
Front:
Depends on your front wheel spec. Mine's currently on et50 7.5", with a 7mm spacer, and the front wheels are too tucked in. I'll be moving to et50 8.5", so 12mm further out... I'll then add a spacer to get the stance right if needed.
Summary; 15mm spacers all round are nothing excessive.
2000 996, C2, manual, arctic/metropole, Koni shocks, H&R -30 springs, H&R ARB's, Rennline SS engine mounts, cup wheel, 170k miles. 2018 Touareg RLine Plus
coullstar
PostPosted: Wed Nov 21, 2018 2:18 pm    Post subject: Reply with quote
Im on M030 and its a good compromise for looks and all round use. With an aerokit the car needs to be on at least the M030 suspension if not around 30mm, as you are looking at.
Im going to around 30mm as well which I will admit is a lot to do with looks as well. As my car is not a daily Im not bothered about a little impracticality.
As for spacers 15mm on std rear wheels is easily accommodated. Front you could probably get away with same but 10mm is probably about right. I hate the tucked wheels look, always have and always will. Probably why I am one of the few people that really doesn't like the e-type Jag look. Compare that to the Eagle Speedster which looks so much better IMO.
You have to watch with the balance, I try to keep track increases even across the axles if possible. If not a little more up front if possible.
2000 Audi B5 RS4
NedHan79
PostPosted: Wed Nov 21, 2018 3:11 pm    Post subject: Reply with quote
Thanks for the input guys. Stotty if your moving to bigger spacers, I’d be interested in the ones your taking off. I’m assuming you’ll have to go bigger with studs as well. What you have now seems to be the idea that I was having. Think that and 30mm drop would be close enough for me. I was under the impression that my car had m030 suspension as the dealer said it had but it’s not listed in my extras in the service book. Also I think it sits very high
coullstar
PostPosted: Wed Nov 21, 2018 4:14 pm    Post subject: Reply with quote
It may have been added afterwards but it certainly looks like standard ride height.
2000 Audi B5 RS4
NedHan79
PostPosted: Wed Nov 21, 2018 4:37 pm    Post subject: Reply with quote
I have no experience with 911’s of any sort so I just have to assume it’s standard height. I only really want it to look more like a gt3. I’m open to spring suggestions too
Stotty
PostPosted: Wed Nov 21, 2018 6:01 pm    Post subject: Reply with quote
I won't go to bigger spacers... I'll fit wheels with a more appropriate off set.
You can pick up spacers on ebay with longer studs pretty cheap... I think I paid c.£75 a pair for mine.
If you're going to lower the car I think 30mm is a good target. GT3 is lower than that, but needs to be stiffer as a consequence. You can retain a pretty decent ride/handling balance at -30... my car is a daily, still does the motorway stuff well, and the B road stuff very well.
NedHan79
PostPosted: Wed Nov 21, 2018 6:43 pm    Post subject: Reply with quote
Sorry stotty. I picked you up wrong. I was at work so only glanced over the posts. I’m thinking 10mm at the front and 15mm at the rear. It should look well when it’s dropped by 30mm.
I’m just doing my homework atm and will start to gather stuff up over the next while. I think I need bushings at the front so I’ll have to look into that. I’ll probably get all that I need and just do it all in 1 go.
Where’s good for bushings? Standard or poly?
Stotty
PostPosted: Wed Nov 21, 2018 7:00 pm    Post subject: Reply with quote
If you’re on an 8 or 8.5 front wheel 10mm will be ok.
I only have standard bushes in mine. It’s a daily, and I don’t want it to be too harsh. I am having uprated ARBs fitted next week, along with adjustable engine mounts, and expect that will be it for handling mods.
NedHan79
PostPosted: Wed Nov 21, 2018 7:27 pm    Post subject: Reply with quote
I e only just got my car and haven’t even got 20 miles in it yet. Had a water leak in the passenger footwell on the first day so I pulled it into the garage to dry it out. As it was in there, I did a 3 stage paint correction so it’s alot nicer now than in the picture above. Still waxing it when I’m fit( bad back and waiting on an operation).I also have 4 young kids so it’s hard to get the time.
I’m wanting to lower it for appearances more than anything. I’ll probably go for the poly bushes but not sure. It’s only a weekend toy for the better parts of the year. Winter tends to be for whatever little ideas I have like refurbishing work through the car.
NedHan79
PostPosted: Tue Jan 01, 2019 1:45 pm    Post subject: Reply with quote
Ok so a little update.
Ive bought a set of spax 30mm lowering springs. Waiting on them coming but probably won’t get them in for some time depending on health.
I managed to get a quick look underneath the car but still sitting on the ground. The front shocks are bilstein items with the number 844741-22 on the drivers side. There’s another number but I couldn’t quite see it. Look to be in very good condition. The rears are badly corroded so no sign of part numbers but no leaks and seem to be very tight.
Front arb measures 24mm and the bushes have seen better days so I’ll get poly bushes for that. Need to get a better look at the rest but nothing loose.
The rear arb is 19mm. I have a reciept for poly bushes for it and they look in good condition.
I was told this was an m030 car. Does this add up?
It rides very firm but I thought sits quite high
Griffter
PostPosted: Wed Jan 02, 2019 8:14 am    Post subject: Reply with quote
You need to identify the “dabs of paint” on the springs to be sure.
I’m sure I’ve seen a definitive list somewhere but a quick search found this - any help?:
http://911uk.com/viewtopic.php?t=116768&highlight=springs+marking+color+colour+m030
NedHan79
PostPosted: Wed Jan 02, 2019 10:05 am    Post subject: Reply with quote
Cheers grifter. I’ll have to get it up and get the wheels off for a proper look.
NedHan79
PostPosted: Sun Jan 20, 2019 5:48 pm    Post subject: Reply with quote
A little update. I’ve had a nosey round underneath the car and it looks to be m030 spec ok. Bilstiens, dabs of paint on the springs and 23.5mm front arb.
All bushes look to in decent shape except for the arb’s so going for poly bushes on those. I’ll leave the rest for now until I see how it goes.
As for the spacers, does anyone know the length of the wheel bolts and can you buy longer decent ones as I can easily (and cheaply) make the spacers at work.
It might just be a case of it’s easier to buy the spacers and bolts together.
I still need to sort adjustable rear toe arms as well before I bother with any of it.
