997 : 2004- 74
Boxster : 1997- 14
crash7
PostPosted: Mon Nov 19, 2018 10:14 am    Post subject: 997 Stone Guards - Yellow Tinge! Reply with quote
My original stone guards are beginning to take on a very slight yellow tinge and although in good physical condition, this bug me and I intend to change them.
I would use the Porsche items again, however are there any better options on the market that will not yellow going forward?
With the advancement in PPF has anyone gone down the road of stone guards made by a PPF company? Does PPF yellow in time?
Any info appreciated
FZP
Paul Ricard
PostPosted: Mon Nov 19, 2018 11:09 am    Post subject: Reply with quote
The yellowing would probably be the oxidisation on the top layer.
, similar to headlights. Have you tried polish on them to cut through the oxidisation?
GlenB
PostPosted: Mon Nov 19, 2018 1:28 pm    Post subject: Reply with quote
I recently had Xpel installed to my car and they redid the stone guards with PPF and doubled the PPF up in that area.
Apparently Xpel are now manufacturing the stone guards for Porsche this is due to the yellowing problems that Porsche have had with the 3m manufactured ones so maybe contact your local Xpel dealer.
-- 997 --
PostPosted: Mon Nov 19, 2018 5:05 pm    Post subject: Reply with quote
Taking the stone guards off you need a heat steamer which softens the glue behind the stone guard, pix bellow.... done mibe recently cos of yellowing, decided to go for black but the texture feels rough and slightly thicker than standard! I suggest take them off and fit new ones..
To take the stone guard, have to do it in a certain way otherwise you will be ripping a patch of paint of the body work !!!
J
 Filesize:  1.58 MB
 Viewed:  1789 Time(s)
 Filesize:  1.52 MB
 Filesize:  1.65 MB
 Viewed:  1803 Time(s)
 Filesize:  1.63 MB
TonyC911
PostPosted: Mon Nov 19, 2018 8:38 pm    Post subject: Re: 997 Stone Guards - Yellow Tinge! Reply with quote
How long have they been on the car before yellowing?
I replaced mine recently and it has made a noticeable difference (in that they are now less visible!) for only a small outlay, about £45 I think. I got mine from Prestige Parts on fleabay and they make these claims:
    200 micron thick clear gloss high density polyurethane material specifically designed for automotive paint protection
    Computer cut to exact size and shape of the factory original parts
    UV resistant - will not discolour or turn "yellow"
Only time will tell if these live up to their claims Wink
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
Before
 Filesize:  454.36 KB
 Viewed:  1727 Time(s)
After
 Filesize:  395.09 KB
John H
2011 Porsche 997 Carrera GTS
PostPosted: Fri Nov 23, 2018 6:02 pm    Post subject: Reply with quote
Black stone guards have always been the way to go... Thumb
"Things turn out best for people who make the best of the way things turn out."
 Filesize:  106.32 KB
 Viewed:  1511 Time(s)
MaxA
PostPosted: Mon Dec 17, 2018 11:09 am    Post subject: Reply with quote
Mine went yellow, so I took them off and then had the car ceramic coated.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
TonyC911
PostPosted: Mon Dec 17, 2018 6:56 pm    Post subject: Reply with quote
Ceramic coatings are great, but it will not protect your paintwork against stone chips! Surprised
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
MaxA
PostPosted: Mon Dec 17, 2018 8:27 pm    Post subject: Reply with quote
Nope you need paint protection film for that ... so where do you draw the line?
TonyC911
PostPosted: Tue Dec 18, 2018 8:10 pm    Post subject: Reply with quote
No worries bud. Each to their own. I just didn't want others reading this thread to think that permanently removing these factory installed stone guards was a good idea. Thumb
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
