997 : 2004- 76
Boxster : 1997- 14
Cayenne : 2003- 3
MJA911
2012 Porsche 991 Carrera
PostPosted: Sun Nov 18, 2018 4:04 pm    Post subject: Mystery misfiring at cold start Reply with quote
Posted this in the Boxster/ Cayman forum, same engine vintage so ideas welcome ... Thumb
http://911uk.com/viewtopic.php?t=131035&start=0&postdays=0&postorder=asc&highlight=
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
thecarfixer
PostPosted: Sun Nov 18, 2018 4:13 pm    Post subject: Reply with quote
Check the air flow meter readings with PIWIS. The service manual gives you a load of parameters to check - ambient temp, speed, injector pulse width, ignition timing etc.
I had a funny cold misfire/stutter with my 986 and it was the AFM - car went stonkingly well when it was swapped out.
Used to get Lambda sensor/adaption codes on it after a longish run, but didn't get a CEL.
MJA911
PostPosted: Sun Nov 18, 2018 4:53 pm    Post subject: Reply with quote
Thanks for that, another great suggestion to look into, just what I wanted.
