997 : 2004- 77
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
AlpinaB3S
PostPosted: Sun Nov 18, 2018 1:07 pm    Post subject: Help!!! Bonnet stuck and battery out Reply with quote
Hi
I have removed the battery to charge it overnight and somehow managed to get the bonnet closed. Obviously now the bonnet release catch won’t work and I can’t get in to put the battery back on.
I have tried the red jacking point in the fuse box but don’t expect that would work anyway with no battery in the car.
I have also managed to get the key stuck in the ignition and it won’t come out.
I have read some threads about finding the releas cable in the passenger wheel arch but can’t take the wheel off because the locking wheel but key is in the front Mad
I am getting a bit stressed with it now so any help would be much appreciated
2005 997 Carrera 2S (mine)
2003 Alpina B3S convertible (wife’s)
2016 BMW X6 40d Msport (families)
Magic919
PostPosted: Sun Nov 18, 2018 1:12 pm    Post subject: Reply with quote
You should be able to power it up with the red post and a good earth.
There’s a piece of metal to poke in and release the key. Hole is under a small plastic cover by the key.
997.2 C2S PDK
997.2 C4S PDK
AlpinaB3S
PostPosted: Sun Nov 18, 2018 1:24 pm    Post subject: Reply with quote
Thanks magic.
Will it still power up with no battery in the car?
My jump leads are a bit old and ropey so it might be them. I assumed it wouldn’t work with no battery in
Magic919
PostPosted: Sun Nov 18, 2018 1:38 pm    Post subject: Reply with quote
You wouldn’t need it if you had a working battery, so I’d expect it to function. Some experience delay when they have a flat battery attached, dragging the voltage down.
997.2 C2S PDK
997.2 C4S PDK
AlpinaB3S
PostPosted: Sun Nov 18, 2018 1:49 pm    Post subject: Reply with quote
Sorry didn’t mean to reply 3 times.
I just thought with no battery connected at all it wouldn’t have a full circuit but I am no expert.
Anyway it still doesn’t work and I think the jump leads are ok. I might try another set and see if that works
I have got the key out though thank you for that tip.
New997buyer
Yas Marina
PostPosted: Sun Nov 18, 2018 2:01 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?t=56267
https://www.pistonheads.com/gassing/topic.asp?h=0&f=230&t=1505205
https://rennlist.com/how-tos/a/porsche-997-how-to-open-the-hood-with-a-dead-battery-376086
Hope this helps thumbsup
“Forum signatures with quotes from famous people is a form of pretentiousness beyond compare, Sir!” Abraham Lincoln in conversation with Groucho Marx.
997.1 turbo man
Ex 997.1 turbo tip S, 996.2 turbo tip S, 996.1 C2 man
Cunno
PostPosted: Sun Nov 18, 2018 2:08 pm    Post subject: Reply with quote
If you can't get it to open with a battery attached to the red bit in the fuse box then there is another way.
Near side front wheel well there is a wire cable hidden behind the liner which opens the trunk. You will more than likely need to remove front wheel to get access to arch lines then remove the front right side of the liners and you should see it. Full hard and it will open the trunk.
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
vlad
PostPosted: Sun Nov 18, 2018 2:25 pm    Post subject: Reply with quote
I haven't read through all the posts just going out, but it sounds like a wheel liner off and find the cable release cable (good luck - just hope if you have locking wheel nuts the key isn't in the bonnet !)
The key stuck in the ignition is a feature can't remember the reasons but its documented in the user manual there is a hole by the side of the barrel for a thin wire to be inserted to release the key.
Good luck !!
Flash gotta dash
PostPosted: Sun Nov 18, 2018 2:29 pm    Post subject: Re: Help!!! Bonnet stuck and battery out Reply with quote
Magic919
PostPosted: Sun Nov 18, 2018 2:30 pm    Post subject: Reply with quote
You are connecting in parallel, so shouldn’t need the battery to complete the circuit.
Make sure you have a good earth. You ought to be able to flick on the side lights and see something as a test.
997.2 C2S PDK
997.2 C4S PDK
GMG
PostPosted: Sun Nov 18, 2018 2:40 pm    Post subject: Reply with quote
...this won't help you today but might next time; I rerouted the 'emergency' release wire so that it sits next to the external temperature sensor in the front bumper cover vent... you can tuck it out of the way; you can then always open the trunk...
AlpinaB3S
PostPosted: Sun Nov 18, 2018 3:15 pm    Post subject: Reply with quote
Done it.
Very Happy
Just thought I would try a different earth and used the hinge rather than the lock plate. Worked first time
Thanks for the help gents much appreciated
Magic919
PostPosted: Sun Nov 18, 2018 3:17 pm    Post subject: Reply with quote
Good to hear.
997.2 C2S PDK
997.2 C4S PDK
New997buyer
Yas Marina
PostPosted: Sun Nov 18, 2018 4:47 pm    Post subject: Reply with quote
thumbsup
997.1 turbo man
