997 : 2004- 76
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Kingb4
PostPosted: Sun Nov 18, 2018 11:50 am    Post subject: Exhaust Bracket - Is there a washer? Reply with quote
Hello,
Am after a bit of advice......
I am in the process of changing my exhaust back-boxes. Has been painful so far, as every bolt has snapped or rusted on. So has taken a while to get it all off.
Am now starting to put it all back together (with stainless-steel nuts and bolts). However, am wondering if there was a washer between the exhaust bracket and the metal plate that's attached to the engine. The diagram doesn't show one (between part 28 and part 1Cool, but I can see the remnants of something rusty (possibly a washer) left on one on mine (it was on all of them, but have wire-brushed it off) - see the photo....
Ben
2002 996.2 C2 Cabriolet
 Filesize:  248.74 KB
 Viewed:  596 Time(s)
 Filesize:  31.21 KB
 Viewed:  596 Time(s)
Jamesx19
PostPosted: Sun Nov 18, 2018 11:58 am    Post subject: Reply with quote
I'm amazed you managed to get that bracket off. All the ones I've seen the bolts mostly resemble rivets rather than anything hex shaped!
Nice work
No washer between the two, but I imagine a washer before the nut goes on the bolt.
Maybe treat the area with a rust converter, or grease before reassembly?
1998 C2 Manual + The Full Hartech.
Kingb4
PostPosted: Sun Nov 18, 2018 5:18 pm    Post subject: Reply with quote
Thanks James - will definitely put some rust converter on, before reassembly.
I didn't manage to undo the bolts, I ground off the back of the captive nuts and will replace with nuts and bolts...
