997 : 2004- 74
Boxster : 1997- 14
Donstanley
PostPosted: Sat Nov 17, 2018 10:08 pm    Post subject: Removing standard steering wheel on 997.1 Reply with quote
I have bought a new steering wheel with paddles for my 997.1 Tiptronic, it came with full instructions both for removing the standard wheel and fitting the new one.
I am having problems locating the head of the T30 screw through the hole in the rear spoke of the steering wheel to release the airbag.
There appears no way of seeing the head of the screw, and I cannot feel the head of the screw even with a smaller T25 torx.
Any suggestions much appreciated.
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Sat Nov 17, 2018 10:27 pm    Post subject: Reply with quote
I would preface this rely by saying I've not done this!
I believe you use the hole behind the wheel spoke to released the airbag. (Disconnect battery 1st!)
Once that's out of the way, I believe the torx bolt is beneth it.
stucart
PostPosted: Sat Nov 17, 2018 11:10 pm    Post subject: Reply with quote
Have a look on YouTube for video which should show you how, basically with wheel straight insert screwdriver or allen key vertically through the hole and push up once it contacts spring clip, it should then release the air bag (disconnect battery and wait 10-15 mins before attempting to allow any capacitors to discharge) once you see whats holding airbag it becomes clear, so check for video if still unsure.
Hope this helps.
Now - Jaguar F-Type 2014 3.0 S Quickshift ,White/ Red interior (theme here!) Loving it .
Previously - 997 C4S Tip-S, 2007, Silver/Red and Black Leather, PSE, Sports Chrono, Turbo wheels.
Donstanley
PostPosted: Sun Nov 18, 2018 4:11 pm    Post subject: Removing standard steering wheel on 997.1 Reply with quote
Thank you for replies which I have tried, but without success yet, I am either using wrong technique or just not strong enough.
I had positioned wheel straight ahead to make fitting new wheel in correct position easy. As suggested I may be able to exert more pressure if wheel was turned.
Can I reinsert the key to enable me to turn the wheel with the battery disconnected without causing any problems.
Instructions are very clear to remove key after battery disconnected and not replace key until battery is connected again.
PostPosted: Sun Nov 18, 2018 4:28 pm    Post subject: Reply with quote
Pm sent.
PostPosted: Sun Nov 18, 2018 6:43 pm    Post subject: Reply with quote
A little tip on removing these ..
I use a T20 screwdiver as the head is just about the right size to push on the bar.
Push the bar with one hand then with the other give a descent hit several times to the top of the steering wheel .. always works for me .
Thefinn
PostPosted: Sun Nov 18, 2018 6:47 pm    Post subject: Reply with quote
I cut the head off an old screwdriver which worked perfectly to realse it, you can see it on my progress thread to get an idea.
997.1 C4S CAB
silvermilnec
PostPosted: Sun Nov 18, 2018 11:58 pm    Post subject: Reply with quote
I use a medium sized screwdriver, your feeling for a bar that when pressed against releases the air bag. As you push the bar up and down it should feel like a spring. Also give a bang on the wheel while depressing the bar.
Hope that helps Thumb
1998 968
2000 996 C2
2006 997 4S
2009 997 1.5 Turbo basalt black on black
Donstanley
PostPosted: Mon Nov 19, 2018 8:43 pm    Post subject: Reply with quote
Many thanks for all the advice, I persevered and in the end with minimum force the airbag popped out. Not sure what I did different if anything, but was very easy in the end.
Not total success however as new wheel which is supposed to be straight swop on 997.1 Tiptronic has different connections to the airbag.
Original wheel has 3 connections, 2 the same (1 green, 1 white) and a black one.
New wheel airbag has only 1 connection which is the same as the green one on the original airbag.
At least the main connection to the car is the same.
New wheel is an atiwe wheel, so may need to contact them if seller on eBay cannot help.
Again any info or advice much appreciated.
PostPosted: Mon Nov 19, 2018 9:00 pm    Post subject: Reply with quote
Can you post a couple of pictures please of each airbag connection ..
Im afraid i mainly do standard faults and mods are not my thing but it might ring a bell with someone here .
Gazc2
PostPosted: Mon Nov 19, 2018 9:13 pm    Post subject: steering wheel Reply with quote
I have a pdf for fitting cruise control which covers removing the steering wheel send me a pm with your e-mail and I will ping it over Thumb
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
Donstanley
PostPosted: Tue Nov 20, 2018 2:58 pm    Post subject: Removing standard steering wheel on 997.1 Reply with quote
All sorted now with the help of the seller, thanks for all the advice, I would not have persevered without it.
stucart
PostPosted: Tue Nov 20, 2018 5:52 pm    Post subject: Reply with quote
Glad it all worked out in the end Thumb
