996 : 1997-2005 29
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Osh
PostPosted: Thu Nov 15, 2018 9:40 am    Post subject: Clearing the drain holes on a cab... Reply with quote
So the weather looks really nice for this weekend here in sunny Bristol - so i'm intending to spend a couple of hours doing some winter prep including cleaning the drain holes...
anyone know of a good YouTube video that shows the best way of doing this...??
Thanks in advance
Osh
PostPosted: Thu Nov 15, 2018 9:47 am    Post subject: Reply with quote
Remove the plastic rivets out the front part of your rear wheel arch liners, pull the liner back to reveal the drain hole, pour water over the side of the soft top between rear quarter window and rear of soft top so water runs down the drain, then poke the shoite out the drain hole with a knitting needle or the likes. Jump back quick whilst everything comes flooding out.
PostPosted: Thu Nov 15, 2018 9:48 am    Post subject: Reply with quote
Don't forget to put your liner back in place and replace the plastic rivets Thumb
Osh
PostPosted: Thu Nov 15, 2018 11:26 am    Post subject: Reply with quote
Thanks Alex Thumb
Now be a good chap and pop outside and film that for me; make sure its in 4K and you don't have any camera shake...
Post up here when your ready. Top man...
Osh
(man-hugs from sunny Brizzol Grin )
Kbald
PostPosted: Thu Nov 15, 2018 4:40 pm    Post subject: Reply with quote
Also take the rear speakers out and remove the splashguard to make sure that the tray is clear and the tubes are connected and not split.
More info here thanks to Alex and others previously
http://911uk.com/viewtopic.php?p=1190654&sid=5622de728295cf23b14de3d6096a7265
2000 Carrera C4 Cabrio Tiptronic
PostPosted: Fri Nov 16, 2018 7:24 pm    Post subject: Reply with quote
Picts for you ..
 Filesize:  789.44 KB
 Viewed:  624 Time(s)
 Filesize:  702.17 KB
 Viewed:  624 Time(s)
 Filesize:  790.5 KB
 Viewed:  624 Time(s)
