996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
toddy2
PostPosted: Mon Nov 12, 2018 5:06 pm    Post subject: Car sounds lumpy - Advice please... Reply with quote
Hi All,
Picked up my car at the weekend after having a full new exhaust including 200 cell cat.
Only driven it home 40 odd cross country miles, it drove and sounded like a dream, very addictive.
Not driven it again until today and it just sounded lumpy, best way to describe it, it sounds like an old VW beetle, and feels sluggish. Had to drive it on a 200 mile cross country trip to plenty of places to open it up and warm up. Occasionally it sounded good, but largely just lumpy.
It sounds fine on iddle and revving standing.
Before I go back to Topgear, just want to make sure there's nothing else it could be, or something simple I should do. Anyone else experienced this?
Thanks in advance......
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944
Marky911
Watkins Glen
PostPosted: Mon Nov 12, 2018 5:39 pm    Post subject: Reply with quote
Does it just sound lumpy or is it lumpy?
If it's misfiring then that's a separate fault affecting the sound.
If it's smooth and firing on all cylinders but just sounds a bit poop, then yep thats the new stuff for you.
After seeing and hearing my mates with all the combos of TG stuff I quickly decided it's not for me. It's ok budget stuff but they just don't put enough effort into tuning the sound.
Their service is good though so I'm sure they'll try some options for you.
Good luck.
toddy2
PostPosted: Mon Nov 12, 2018 7:10 pm    Post subject: Reply with quote
Good luck.
Difficult to define, very rarely it's smooth. Sounds lumpy and drives as if there's something restricting it.
1968 911T
2002 996 4s
1988 944
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Nov 12, 2018 7:51 pm    Post subject: Reply with quote
Maybe a coincidental fault, such as Coils? Or maybe the new cats causing the ECU to change the engine settings incorrectly?
PostPosted: Mon Nov 12, 2018 8:03 pm    Post subject: Reply with quote
Perhaps a sound clip would be helpfull ..
Im thinking possible misfire atm to be honest .
kas750
Reims
2006 Porsche 911
PostPosted: Mon Nov 12, 2018 8:05 pm    Post subject: Reply with quote
Sounds like a coil pack/ coil pack connector could of been disturbed.
alex yates
PostPosted: Mon Nov 12, 2018 8:07 pm    Post subject: Reply with quote
yes
toddy2
PostPosted: Mon Nov 12, 2018 8:08 pm    Post subject: Reply with quote
Thanks deMort, I'll try and post one up shortly. I'm taking in to my local mechanic for a few bits, including: window regulator; change over seat belts. I might get him to replace the maf sensor and coil pack.
When the new exhaust was fitted, it had a new lamb sensor could that be it?
1968 911T
2002 996 4s
1988 944
PostPosted: Mon Nov 12, 2018 8:27 pm    Post subject: Reply with quote
First off .. dont throw parts at the car .. i do hate people doing that .. it costs money !
Its possible the car is actually adapting to the new exhaust ..
Basically the car trys to maintain Lambda on each cyl .. (correct fuel / air ratio ) .. it takes a while to do this when new parts or fault codes have been cleared .
Its basically the car adapting to worn components and is normal .
You need in the region of 50 miles to get sensible adaptions and to know if there is actually a fault .. with a tester then a bit quicker as you can see the engine values and fault codes that might not generate an eml on .
For my part .. and as ive said im not a mod guy then the car will need to adapt and possibly even be mapped to get the best from the exhaust.
Porsche have a set map in the DME for the Set exhaust .. you have changed this so the flow characteristics have changed and may well need a remap to get it correct .. ask Top gear there as this isnt my area of expertise im afraid .. i do standard stuff Smile .
EDIT ..
A new Lambda sensor one side but not the other will often throw up an ageing fault with the one that hasnt been changed .. i always recomend replaceing in pairs .
toddy2
PostPosted: Mon Nov 12, 2018 9:34 pm    Post subject: Reply with quote
Thanks as always deMort.
It's a mod out of necessity, needed a whole new exhaust and oem prices were crazy.
I've done 250 miles now with no improvement, so will get a diagnostic done. Good idea possibly remap too.
1968 911T
2002 996 4s
1988 944
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Mon Nov 12, 2018 10:30 pm    Post subject: Reply with quote
+1 on the diagnostic check before going down the remap route. I’ve just had a full system put on my 997.1 C4S and have put over 500 miles on it without any problems. I think kas750’s suggestion is looking pretty likely.
Hope you’re sorted soon and able to get back to enjoying the sound which, imho, is far from ‘poop’.....but each to their own. Thumb
997.1 C4S Meteor Grey Manual
Stoo.c
PostPosted: Tue Nov 13, 2018 9:20 am    Post subject: Reply with quote
I had an almost identical problem with my top gear exhaust however it was intermittent which was even more annoying. I was really unhappy with it. Turns out it was blowing in certain circumstances despite me using all of the new gaskets, fittings etc. I replaced all of the gaskets and clamps with new Porsche ones and made sure it was well sealed. Problem solved now - unfortunately at the cost of the Top Gear exhausts, I think it has to be expected that there are certain corners cut.
I'm happy enough with it now. Would I buy it again - probably not but I do however think its fairly good value for money.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
Martin996RSR
PostPosted: Tue Nov 13, 2018 1:27 pm    Post subject: Reply with quote
Can the OP please change the title of this thread to remove the reference to Top Gear? The likelihood of the fault being down to the exhaust is very low indeed. I know, because I have one, and I have a lumpy idle that I'm pretty confident is down to a lazy lifter. There are any number of things it could be on the OP's car and when reading the thread title, people will infer the problem is caued by the exhaust, when it won't be, and Top Gear's good name will have been tarnished unfairly.
By all means change the title back once you've proven the fault lies with the TG exhaust and not your car.
alex yates
PostPosted: Tue Nov 13, 2018 1:33 pm    Post subject: Reply with quote
Thumb That's a fair point.
toddy2
PostPosted: Tue Nov 13, 2018 4:47 pm    Post subject: Reply with quote
Fair comment, have amended for now until I've had time to investigate....
1968 911T
2002 996 4s
1988 944
toddy2
PostPosted: Wed Nov 14, 2018 9:21 pm    Post subject: Reply with quote
Nothing has come up on the diagnostic, I've had the coil packs changed, and mass flow sensor. Still no improvement, I'll try running it more to see if there is any improvement.
1968 911T
2002 996 4s
1988 944
alex yates
PostPosted: Wed Nov 14, 2018 11:32 pm    Post subject: Reply with quote
Mine have sounded dog rough recently so after a good snoop round I noticed me clamps/sleeves between cat and back boxes where weeping slightly. Noticed it when cold under inspection as the condensation was blowing bubbles round the joints, but when hot, it's not as easy to see but sounded worse.
toohey
PostPosted: Thu Nov 15, 2018 12:03 pm    Post subject: Reply with quote
Which silencer option did you go for? - only reason i ask is if its the switchable option and one side is switched the wrong way would make the exhausts have very different flow characteristics? There is a very noticeable difference in the switchable system on mine......
Marky911
Watkins Glen
PostPosted: Thu Nov 15, 2018 4:52 pm    Post subject: Reply with quote
My exhaust sleeves have dropped water on every set of sleeves and exhausts I've had, including on my GT3. Even when using brand new genuine sleeves.
I've always wanted to gun gum them up but Craig is adamant they're a clean fitting. I'm going to add some paste over winter though out of interest.
As Alex says if condensation can get out then obviously air can.
Good point about checking the valves but if TG fitted them I'd expect them to be fine. Thumb
Stoo.c
PostPosted: Fri Nov 16, 2018 11:25 am    Post subject: Reply with quote
Exactly what I did - put some assembly paste in some new sleeves and then it was finally sorted. Took me ages to actually work it out as it was intermittent depending on temperature etc. It sounded so bad that I thought I'd dropped a coil.
02 996 C4S
91 CRX vtec turbo
01 986 Boxster S
