997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Chuckmiester
PostPosted: Mon Nov 12, 2018 6:20 am    Post subject: Coolant loss Reply with quote
Drove down to the nec for the classic car show on Saturday from Barnsley roughly 90 miles each way. Checked the oil and water yesterday and it had used around a cup full. There are no signs of any leaks anywhere. I’m thinking the worst and wondering if it could be the head gasket that’s leaking. There doesn’t appear to be any water in the oil yet. The engine was rebuilt around 5 years ago at strasse in Leeds we’re they put 6 new liners in. Does anyone have any more ideas what it could be? Thanks in advance Dont know
2003 c4s arctic silver
2017 Range Rover velar
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Nov 12, 2018 6:58 am    Post subject: Reply with quote
How old are the radiators?. Could also be the header tank.
Chuckmiester
PostPosted: Mon Nov 12, 2018 7:48 am    Post subject: Reply with quote
radiators are around 4 years old. I replaced both of them. I thought header tank but it’s holding pressure a for a good hour at red car has been turned of.
alex yates
PostPosted: Mon Nov 12, 2018 7:52 am    Post subject: Reply with quote
Never compare water level until you know the system is fully down to ambient temperature - which will easily take over 5 hours. The level fluctuates a fair amount during the heating/cooling cycle due to heat expansion.
I only ever check my coolant level when the car has been stood over night unused.
Chuckmiester
PostPosted: Mon Nov 12, 2018 7:59 am    Post subject: Reply with quote
level was checked 24 hours after the car was parked up.
alex yates
PostPosted: Mon Nov 12, 2018 9:06 am    Post subject: Reply with quote
Have you checked your footwell carpets? Although your heater usually gives off a wiff if that's leaking.
Best way to find a leak is leave the car runbing on the drive for 20 minutes after already up to temp. Pressire is at its highest then and everything is fully expanded so any micro-crack in your systems will them leak coolant.
alex yates
PostPosted: Mon Nov 12, 2018 9:07 am    Post subject: Reply with quote
Most likely a small crack in a rad or a weeping hose joint.
Jamesx19
PostPosted: Mon Nov 12, 2018 9:20 am    Post subject: Reply with quote
I think Alex's assessment is more likely than head gasket etc.
I had a hose clip that needed nipping up. I was loosing half a cup of coolant every time I drove the car. There was no signs of leaking at all. I.e. nothing under the car. The water must have just been evaporating off.
A clue might be temperature fluctuations on the guage rather than steady 82 Deg. Which may point towards the system not fully pressurising due to a slight leak.
Demort might be able to confirm, but I presume a garage may be able to pressure the system to leak detect???
1998 C2 Manual
Chuckmiester
PostPosted: Mon Nov 12, 2018 10:06 am    Post subject: Reply with quote
no temperature fluctuations at all. I had it running on the drive for about half an hour and no leaks were visible. There was still pressure in the tank an hour later when I took the cap off. The cap is very tight to get off.
Griffter
PostPosted: Mon Nov 12, 2018 10:15 am    Post subject: Reply with quote
How often do you do a 180 mile round trip? Could it be an air pocket that finally got out?
See if it does it again, then worry about it. If it does I’d start by rigorously checking all connections, especially those you disturbed four years ago, and looking for congealed coolant around the joins.
Chuckmiester
PostPosted: Mon Nov 12, 2018 10:34 am    Post subject: Reply with quote
not often it gets a good run like that now we have a 15 month old and another on the way. Very Happy
Chuckmiester
PostPosted: Tue Nov 13, 2018 7:46 am    Post subject: Reply with quote
Had a look at the coolant cap this morning and the part number finishes in 01. Might be worth getting the newer version before doing anything else.
Ghianightmare
PostPosted: Tue Nov 13, 2018 7:51 am    Post subject: Reply with quote
If there is white deposits around the cap on the bottle and engine bay trim, this is an indication that the lid is leaking. It only costs about £20 so it is a cheap place to start.
2002 Seal Grey C4S
Chuckmiester
PostPosted: Tue Nov 13, 2018 8:11 am    Post subject: Reply with quote
There’s no evidence of any residue around the cap.ive not noticed it leaking before now though. I don’t know how much coolant would have to leak past the cap to leave a mark?
alex yates
PostPosted: Tue Nov 13, 2018 8:21 am    Post subject: Reply with quote
Can't see it being anything to do with the cap if it's holding pressure.
