Posted: Sat Nov 10, 2018 4:47 pm Post subject: Exhaust tip removal
I planned to take the tips offf the exhaust in the morning and give them a good clean and polish. I’ve soaked everything in WD40 in the hope they will come off easily, but i’m sure the grinder will come out...
I’ve read that even with the clamps off they can still be a pig to remove so wondered if anyone had any ‘tips’ To make it easier.
Also cleaning before polishing... has anyone tried oven pride, the stuff you put in a plastic bag and soak. _________________ 997.1 C2S Cab Tip.
-- 997 -- Suzuka
Posted: Sat Nov 10, 2018 7:24 pm Post subject:
Soak the bolt area and pipe with WD40 overnight and should come off easy, if not use a rubber mallet and it will definetly come off without damage!! Once off put them in hotwater for a proper clean up using a brush then get them polished as below !!
J
Filesize:
1.23 MB
Viewed:
897 Time(s)
silvermilnec Barcelona
Joined: 20 Feb 2012 Posts: 1498 Location: Leeds West Yorkshire
Posted: Sat Nov 10, 2018 7:50 pm Post subject:
I soaked mine in one of those bag things overnight and tried just about everything but in the end I had them re plated, cost about £70 and worth it imo. My tips came off easy _________________ 1996 944
1998 968
2000 996 C2
2006 997 4S
2009 997 1.5 Turbo basalt black on black
deMort Zolder
Posted: Sat Nov 10, 2018 7:55 pm Post subject:
I have found in the past that a metal punch on the clamp side and hitting top and bottom works .. as does heat .. hot air gun will do .
Need to have the car raised to do this though ... i have a ramp _________________ .
After putting mine back on, even at maximum tightness, they were still loose. Thankfully a kind forum member and a coke can came to the rescue. _________________ Current: 997.2 C2S, Audi TTS mk3
Previous: Cayman 987.1, Audi TT mk1 , BMW e46
