996 : 1997-2005 29
Boxster : 1997- 14
ayton1
PostPosted: Fri Nov 09, 2018 8:22 pm    Post subject: Centre Gravity Reply with quote
I have not been happy with the way my car wanders at high speed & after reading about Centre Gravity on here & Pistonheads decided I needed a trip down. After getting booked in approx 3/4 weeks wait (must be good) off I went at 5.30am for my slot at 8.30. There usual treatment initially drive as is, back to shop for adjustments & drive again.
Mine was all within Porsche spec but after they had carried out their changes it’s a different car, tracks a straight line now & feels much more planted. Another surprise is how much lighter the steering feels & it now straighten’s up itself out of corners.
All in all an interesting day & a very satisfied customer.
 Filesize:  873.94 KB
 Viewed:  2201 Time(s)
Kettmark
PostPosted: Fri Nov 09, 2018 8:32 pm    Post subject: Reply with quote
What were the costs for the checks and adjustments?
kas750
Reims
2006 Porsche 911
PostPosted: Fri Nov 09, 2018 8:37 pm    Post subject: Reply with quote
+1
G2
PostPosted: Fri Nov 09, 2018 8:44 pm    Post subject: Reply with quote
Was anything changed or just adjustments?
997 Gen2 Turbo S - Speed.
991 C4S - Riviera.
ayton1
PostPosted: Fri Nov 09, 2018 9:39 pm    Post subject: Reply with quote
Ended up spending just short of £500.00 which included changing a rear track control arm with a oem one they had in stock.
It was all just settling changes really. Track control arm wasn’t bad , but made sense to have everything right while I was there.
Kettmark
PostPosted: Fri Nov 09, 2018 10:07 pm    Post subject: Reply with quote
How often do they recommend this is done please?
New997buyer
PostPosted: Fri Nov 09, 2018 10:13 pm    Post subject: Reply with quote
What they do, they do extraordinarily well. Big fan myself, and I know a few others too. Not surprised at your experience. Delighted your delighted Thumb
Jcx
Estoril
2010 Porsche 997 Turbo
PostPosted: Sat Nov 10, 2018 3:27 am    Post subject: Reply with quote
I used them for the first time last month. What a transformation. Stunning.
FZP
Paul Ricard
PostPosted: Sat Nov 10, 2018 10:03 am    Post subject: Reply with quote
I'm a huge fan. When you think of the term artisan, you think of people who make things, bread, wood workers, blacksmiths, etc. But these guys are just the best. I'd put them in the Artisan cat for sure.
PostPosted: Sat Nov 10, 2018 10:22 am    Post subject: Reply with quote
Chris is most definitely a 911 handling aficionado.
Marky911
PostPosted: Sat Nov 10, 2018 11:33 am    Post subject: Reply with quote
That's how I'd describe it, although I've only been with a mates car, not my own yet.
Before I went I knew they must be good but I did think "Well how much better can they do an alignment? There's only so many things you can adjust and anyone can adjust them".
It's the thought behind the adjustments though and how one tiny thing affects the next and so on.
I'll be visiting at some point although I couldn't justify it every year which is what most people recommend.
It's a fascinating day out though and good to know that when you leave your car is simply the best it can be with whatever components you have on it.
PS. Ayton that's a lovely car and an even nicer garden/courtyard. Cool
PostPosted: Sat Nov 10, 2018 3:06 pm    Post subject: Reply with quote
Once I'd got the fully monty done at CG I'd get down kwik-fit for a free check on their Hunter system & get a print out. You can then return back to kwik-fit every 6 months/year and do a comparison. If something looks like it's wrong, then get checked back in to CG.
https://www.kwik-fit.com/wheel-alignment
tom_nieto
PostPosted: Sun Nov 11, 2018 2:32 pm    Post subject: Reply with quote
Another very satisfied CG customer here! They really know their stuff.
Go and put some miles on it and come back if you have a bump or notice any creaking was their advice to me!
rabbitstew
PostPosted: Mon Nov 12, 2018 11:23 am    Post subject: Reply with quote
Im glad you tried them out in the end!
2008 997.1 Turbo Manual - 585whp thanks to do88 & 9e
2000 Ducati 996
1999 Yamaha R1
1994 Kawasaki ZXR750L2
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Nov 12, 2018 11:51 am    Post subject: Reply with quote
In the CoG FAQ it says they give you comprehensive before n' after settings for you to apply elsewhere if necessary.
Costwise, it says they work at £75+vat an hour, which is similar to an indy. It says a typical geo takes 4 hrs, so £360 all in as a starting point.
This also makes one realise that the basic 'geo' done by specialists for around £100 must be a bare-bones service.
Seventy Seven
PostPosted: Tue Nov 13, 2018 7:11 pm    Post subject: Reply with quote
Really interesting.... Mine was all done at OPC when I purchased and always felt planted, etc.
However, since I changed rear tyres last year, it has not felt the same and 'wanders' as said above. Not sure if just in my head and has improved since bedding in the tyres.
I do low miles a year, so not sure if I need checked or it is as it should be. Is there a similar outfit in the south?
Current:
997.2 C2S, Meteor Grey, PDK (with paddles), PSE, Sports Chrono, etc.... (2009)
Range Rover Evoque, Dynamic Lux, Black (2015)
Hamster75
PostPosted: Tue Nov 13, 2018 7:32 pm    Post subject: Reply with quote
My car seems fine & tracks good I've not noticed any issues, however from feedback on here its seems like the place to go for setting up your Porsche.
As I plan on keeping my car, when the time comes & gets tired sussys I think I will give them a try.
DucatiRob
PostPosted: Sat Nov 17, 2018 6:53 pm    Post subject: Reply with quote
Have had some comms with CG in the last couple of weeks about getting mine booked in, the front end is a little crashy at low speed and it has never felt as grippy and planted as it used to since swapping my wheels and changing from Bridgestone Potenzas to MPSS last year. Expect the top mounts need doing and probably control arms!
Have been planning on swapping over to Ohlins R&T and had been thinking of doing the work myself then getting a full geo at CG, they have given me some estimates and pricing is surprisingly good value, so might get them to do everything! Really helpful and good comms too Thumb
Mercedes CLK DD
Ducati 996
davidjf7
PostPosted: Thu Nov 29, 2018 12:00 pm    Post subject: Reply with quote
Going up there tomorrow morning - super excited thumbsup
