996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
davidjf7
PostPosted: Thu Nov 08, 2018 4:25 pm    Post subject: Clicking noise when pulling away Reply with quote
Hi guys,
Anyone had this - a loud clicking noise from under the car when pulling away.
Not straight after releasing the brakes, but maybe a second later.
Car is a PDK
Tried to google it and wondering if it's a driveshaft?
alex yates
PostPosted: Thu Nov 08, 2018 4:37 pm    Post subject: Reply with quote
C2 or C4?
neil_911
PostPosted: Thu Nov 08, 2018 4:40 pm    Post subject: Reply with quote
Might be the brakes and the rattle clip thingies.
Mine do it abit, wouldn't call it a loud clunk, Just a click like the pads move slightly when brake pressure is released and the wheel starts turning.
More evident when up to operating temps and the brakes have been used a fair bit. Cop
Basalt Black 997.2 C2S PDK - for the weekends
Mercedes S500 5.0L V8 - for the commute
davidjf7
PostPosted: Thu Nov 08, 2018 5:08 pm    Post subject: Reply with quote
alex yates wrote:
C2 or C4?
C2 - good shout
davidjf7
PostPosted: Thu Nov 08, 2018 5:09 pm    Post subject: Reply with quote
yes, def not a clunk - will see if it does it when cold tonight!
davidjf7
PostPosted: Fri Nov 09, 2018 9:17 am    Post subject: Reply with quote
So, it only does it when warm..
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Fri Nov 09, 2018 5:33 pm    Post subject: Reply with quote
Have you checked nothing is fouling wheels and tyres?
- thinking broken coil spring.
But there are lots of possibilities.
Are you turning when it makes the noise?
Does it have LSD?
neil_911
PostPosted: Fri Nov 09, 2018 7:24 pm    Post subject: Reply with quote
My moneys on the brakes then.
I've tried to sort mine out, greasing up the contact points of the pads. But still does it. Used to it now, It only became apparent when i put some brembo pads in, and not porsche ones. Even though it shouldn't make a difference. I just wonder if porsche ones are a slightly better fit.
PostPosted: Fri Nov 09, 2018 8:45 pm    Post subject: Reply with quote
Just a thought but make sure the bolts for 8 / 10 here are as tight as you can get them .
https://www.deroure.com/diagrams.asp?TBL=2822&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
davidjf7
PostPosted: Mon Nov 12, 2018 9:42 am    Post subject: Reply with quote
Thanks all.
Nothing rubbing that I can see - it sounds like something releasing with a clicking noise.
Only noticed it in a straight line.
Front discs and pads were changed by OPC two years ago.
Thanks deMort - do you mean bolts 9 and 12? Thumb
