997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
Britince
PostPosted: Thu Nov 08, 2018 8:11 am    Post subject: 997.2 rear light damage - any ideas? Reply with quote
Hi Everyone.
By a process of elimination, I’ve worked out that the green circuit board inside the light casing has failed on one of my rear led lights. The rest of the light is fine and works perfectly if I swap the circuit board across from the other good light.
Anyone got one or know where I can get a replacement without having to buy a whole complete light unit?
Also, has anyone gone down the circuit board repair route?
Any thoughts or offers much appreciated.
Thanks,
M
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Thu Nov 08, 2018 2:20 pm    Post subject: Reply with quote
The Gen2 rear lights usually fail by cracking and letting water in.
They then get replaced - either under warranty or at owners expense.
Have you tried ebay, breakers and gumtree?
If you've a good relationship with your local OPC, they might give you a part they've replaced
That's v rare but I've heard it happens
Magic919
PostPosted: Thu Nov 08, 2018 4:15 pm    Post subject: Reply with quote
How much do you want to pay for it?
997.2 C2S PDK
997.2 C4S PDK
Britince
PostPosted: Thu Nov 08, 2018 5:12 pm    Post subject: Reply with quote
As little as possible if I’m honest. Someone on this site has offered me a pair for £100 which I will buy if there are no other options but I only need one board.
I was hoping that someone out there might have a damaged light which therefore cannot be sold as a working unit and therefore might be happy just to sell a single circuit board.
Regards,
M
Britince
PostPosted: Thu Nov 08, 2018 5:14 pm    Post subject: Reply with quote
Thanks Jonno.
That’s a good suggestion - I’ll give that a try.
M
Magic919
PostPosted: Thu Nov 08, 2018 7:00 pm    Post subject: Reply with quote
Didn’t someone offer you circuit boards the other day?
997.2 C2S PDK
997.2 C4S PDK
Britince
PostPosted: Thu Nov 08, 2018 7:47 pm    Post subject: Reply with quote
Yes, as I said earlier, someone did offer me a pair. Whilst I’m waiting to hear back from them, I don’t actually need both so wondered if someone might have an individual one to sell.
Clanky
2007 Porsche 997 Turbo
PostPosted: Fri Nov 09, 2018 5:58 pm    Post subject: Reply with quote
If I were you, I'd snap up the pair for £100! That's an absolute bargain. The boards should be easily swapped over too as far as I remember...
996 C4s (Gone)
997 Turbo
S3 Daily Driver
Gottans
PostPosted: Sat Nov 10, 2018 8:59 am    Post subject: Reply with quote
Worth noting that somewhere down the line the colour of the plastic body of the individual LEDs in the light cluster changed from yellow to clear. Doesn't affect the colour of light when lit but when not lit there is an obvious difference.
When one of my rear lights started leaking enough (both had issues) for a warranty claim, the warranty ended up paying to change the pair to make sure they matched.
v6matt
PostPosted: Sat Nov 10, 2018 12:59 pm    Post subject: Reply with quote
Probably more hassle/maybe more expensive but a local electrical tester may be willing to take a look/fix the problem with your existing board.
If it was mine, I would it out. Look for any poor solder points/burnt components. Do the necessary and see if it works.
2008 Carrera 4 - Gen 1 997
