997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
NLW73
PostPosted: Tue Nov 06, 2018 8:29 pm    Post subject: Rear light bulb warning near side Reply with quote
Driving home from work
Have had an alert that the rear light bulb is out when lights go on.
Turned off ignition and then It stays on for like 15 seconds then goes out.
Seen this before ? Faulty connection or would it be bulb and normally a bulb just goes out
There is sth buzzing or whirring in the engine bay I noticed too
Any advice welcome
997 C2s Schwarz
jl-c
PostPosted: Wed Nov 07, 2018 10:25 am    Post subject: Reply with quote
have you actually looked if a bulb has failed? If they all appear to be illuminated when checking visually then it may be a high resistance issue. Replace the 'faulty bulb' or if it's working clean the contacts (bulb and holder) with a bit of scotchbrite. This should remove any corrosion that could be causing the higher than normal resistance, hence bulb fail, or of course bang in a new one, but check the contact are clean first. AFAIK the 'warning' does stay on for a few seconds after turn off. The buzzing from the engine compartment, was the ignition on? If so (again as far as I remember) that is the throttle resetting itself, no big deal in fact it makes sense to do it every now and again as it forces it into relearn mode ref your driving style.
NLW73
PostPosted: Wed Nov 07, 2018 12:46 pm    Post subject: Reply with quote
thanks and will do that.
the bulb inside looks fine and no broken wire inside
could be the contacts with bulb and wiring so will hit that next.
997 C2s Schwarz
NLW73
PostPosted: Thu Nov 08, 2018 5:04 pm    Post subject: Reply with quote
was the wrong bulb in there.
was a single filement and now changed to dual.
997 C2s Schwarz
NLW73
PostPosted: Thu Nov 08, 2018 5:07 pm    Post subject: Reply with quote
997 C2s Schwarz
NLW73
PostPosted: Thu Nov 08, 2018 5:08 pm    Post subject: Reply with quote
997 C2s Schwarz
NLW73
PostPosted: Thu Nov 08, 2018 5:09 pm    Post subject: Reply with quote
997 C2s Schwarz
chowgar
PostPosted: Fri Nov 09, 2018 3:05 am    Post subject: Reply with quote
Are you Rain Man?
“Charlie Babbot, Charlie Babbot, Get the papers,
Aghh, Aghh, Aghh...
