996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
maldren
PostPosted: Tue Nov 06, 2018 4:40 pm    Post subject: Ebay Litronic issues Reply with quote
I've bought a pair of Litronic facelift headlamps from different vendors.
Lamp 1 is fine but it came with the washer removed. Having tried to get it back I can wee why. Anyone done it? What sequence do the parts go back in?
The other light was damaged in transit. The projector assembly had come loose. I'm following up with the vendor but it seems a shame not to be able to fix it. Has anyone ever taken one apart and rebuilt it?
thanks
Mike
Mike
PostPosted: Tue Nov 06, 2018 7:47 pm    Post subject: Reply with quote
Can you post some pictures please of whats broken .. do you mean headlight washer is missing ? is this the outer cover or the nozzle as well ? again a picture please so i can see whats actually missing.
Griffter
PostPosted: Wed Nov 07, 2018 7:52 am    Post subject: Reply with quote
Not sure it’s much help but on the 996.1 (pre facelift) the washer is seperate from the headlamp and fixed to the bodywork under the bumper cover via a bracket and two bolts. The washers are handed. Replacement is straightforward enough but requires front PU to be removed.
maldren
PostPosted: Wed Nov 07, 2018 8:35 am    Post subject: Reply with quote
Thanks Iain
Here are the washer components. It seems that I need to put the 2 seals in place first and the jet/chrome cover are fitted from the outside after the remainder is in place.
However, it's very hard to get the main body into place. Am I correct about putting the seals in first and do I try to put the main body in in one piece or do I fit the part that goes through the lens first and then fit the larger part?
thanks
Mike
Mike
 Filesize:  341.49 KB
 Viewed:  714 Time(s)
PostPosted: Wed Nov 07, 2018 8:11 pm    Post subject: Reply with quote
Aghh i see ..
Theres no way i can explain how to do this in words so hopefully this will help .
https://www.youtube.com/watch?v=s3L_2ozmZn8
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Wed Nov 07, 2018 10:15 pm    Post subject: Reply with quote
I have stripped my Litronic's down and it is very fiddly in that there is no guide out there and knowing the cost to replace you have to tip toe through the strip down and don't force anything as there are clips and screws which aren't obvious at first. I think I did a write up on here somewhere but unsure where it is.
Found it, it's in the 996 FAQ's http://911uk.com/viewtopic.php?t=124477
maldren
PostPosted: Thu Nov 08, 2018 8:42 am    Post subject: Reply with quote
Many thanks both.
Iain,
looks like it's what I thought, tricky to get the main body in, I'll have another go today.
IS,
Perfect, this is just what I was hoping for. Now to dig in and see what the courier managed to (hopefully) dislodge or break.
Mike
maldren
PostPosted: Thu Nov 08, 2018 5:03 pm    Post subject: Reply with quote
Both lights now fixed, many thanks again Iain and IS.
Fitting the washer mechanism is tricky, to fit the part that goes through the front lens you really need longer fingers than I have. Eventually I used a fine bladed old kitchen knife to guide it into the seal and then pulled it into place from the outside. For the other, larger part, fit the rear seal first and then wetting it with soapy water helps it slide in much more easily.
Stripping the light down was greatly helped by IS's thread. The only thing that wasn't obvious is how the beam adjusters fit through the side of the light. Loosen the inner part as described by IS and pull it out about 2mm, you can then release the adjusters out from the outside of the light. You can then slide the inner part out completely. Fit in reverse.
My light had obviously been thrown around in transit and on the main beam assembly the pivot balls had come out of the sockets. The metal heat shield between the main and dip beam had also come off, looks like it had some sort of soft, rubbery glue to hold it in place so I used Uhu rather Araldite. All refitted and working fine although I'm sure the beams will need adjustment.
Interestingly, I didn't need to make any wiring adjustments to get the main beam and fog lights to work with the Litronics, it really is plug and play on my 2003 facelift car.
Mike
Mike
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Thu Nov 08, 2018 5:12 pm    Post subject: Reply with quote
Glad it helped somewhat.
I need to strip my N/S headlight again as one of the reflector bits inside came loose when I was on a bumpy road in France.
