997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Dammit
Watkins Glen
PostPosted: Thu Nov 08, 2018 8:25 pm    Post subject: Reply with quote
Mid-last year, and yes it was with the engine out.
The noise sounds like it's coming from the pedal itself, and I was told it was the bushings in the pedal that needed to be changed when I picked it up from it's last service - which given where it sounds like the noise is coming from I didn't question.
It might still be something in the gearbox - but most things that move have been changed, so I'm at a bit of a loss as to what. That said, I'm hugely ignorant.
PostPosted: Thu Nov 08, 2018 8:49 pm    Post subject: Reply with quote
If its from the rear then its kinda obvious as you can hear it with the door or window open when pressing the pedal .. you dont tend to hear it on normal driveing as well .... the bits in the box have been replaced and greased were needed .. i kinda know that Wink
Booster spring is the more obvious but im afraid we have to change it to eliminate it , as with all noises we cant actually see whats causeing it .. if the item can be seen then we kinda feel it .. hands on different items to feel for the noise .
Booster spring wasnt replaced with engine out so im guessing a while back and for this noise ?
Yup it sounds stupid but it works .
You also have a shaft which supports the pedals with bushes in the shaft , you also have the clutch master cyl .. this has a rod going into rubber seals which can cause noises .. these are more unusual but if the booster spring has been replaced then personnely i would lean towards it being a master cyl.
Now then .. sometimes this can be fixed with a simple spray of lubricant on the rod / end of the slave cyl.
i think for now let me know when / if you are dropping by .. remind me and ill have a look .. if i can fix it easily then i will .
 Filesize:  63.23 KB
 Viewed:  429 Time(s)
Dammit
Watkins Glen
PostPosted: Thu Nov 08, 2018 8:54 pm    Post subject: Reply with quote
Will do, cheers DeMort.
PostPosted: Thu Nov 08, 2018 8:59 pm    Post subject: Reply with quote
I edited to say .. booster spring wasn,t done with engine out .. so just to confirm it has been done and im guessing a year or so ago ?
Dammit
Watkins Glen
PostPosted: Thu Nov 08, 2018 9:04 pm    Post subject: Reply with quote
Yes, booster spring was done in the first big service, directly after I bought the car.
Paynewright
PostPosted: Sat Nov 10, 2018 2:35 pm    Post subject: Reply with quote
Typical since I’ve posted its not done it!! Could be temperature related.
Ian
Goto page Previous  1, 2
Page 2 of 2
