996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
Jamesx19
PostPosted: Mon Nov 05, 2018 10:20 pm    Post subject: Squeaking creaking rattle dashboard FIXED with windscreen tr Reply with quote
Hello,
As I haven't seen the fix on 911UK I thought I'd signpost a link to Rennlist which has helped sort an annoying squeak from the dashboard area of my early 996 C2.
It wasn't the dashboard at all, but the windscreen frame moving againt some trim, or similar. Porsche dealt with it under a TSB 6420 (Technical service bulletin) quite early in the models life (1999 ish) so it may not help anyone experiencing something similar in a later model.
Anyway long story short, Porsche produced a fix, which you can buy from an OPC for the princely sum of £18!
Part no. 996.541.903.00
Link to Rennlist which also contains a link to a PDF so you can download the fitting instructions:
https://rennlist.com/forums/993-forum/628744-anyone-have-copy-of-tsb-6420-windshield-creak-fix-with-rope.html
Worked for me. Hope it's of use
Cheers.
1998 C2 Manual
PostPosted: Tue Nov 06, 2018 8:05 pm    Post subject: Reply with quote
Ive not used that rope before but a common fix was Teflon tape under the screen rubber .. it kinda looks like selotape and seperates the rubber from the bodywork with a smooth surface which stops all the creaks when the frame flexes .
Its almost a chattering noise when you corner or drive on an uneven surface .
Stoo.c
PostPosted: Wed Nov 07, 2018 1:08 pm    Post subject: Reply with quote
Hmmmm - I have a really annoying chattering noise when driving slowly over cobbles for example. Its such a light chattering that I feel it cant actually be suspension related (most of that is new anyway) but this is interesting. Would it still have been present on a 2002 model?
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
Stoo.c
PostPosted: Wed Nov 07, 2018 1:23 pm    Post subject: Reply with quote
I've read the tech bulletin and from what I can see, whilst I should have an updated trim with my 2002 model, I can still suffer from the squeak. Its got to be worth a shot.
02 996 C4S
91 CRX vtec turbo
01 986 Boxster S
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Nov 07, 2018 1:56 pm    Post subject: Reply with quote
Mine does that too occasionally. Seems quite temperature dependent. I've put it down to a coffin arm, but might try this screen fix.
Paynewright
PostPosted: Wed Nov 07, 2018 4:03 pm    Post subject: Reply with quote
996.2 - I have a squeak from the screen that I only get pulling onto the drive in the winter so not to bad,
I also have a f£&king annoying rattle that sound like its coming from between the stereo and the air bag, passengers say its further over towards the dash speaker. I’ve blue tac’d the alarm sensor in the centre - not that. Some days its there all the time others not a peek!
My mate pushed quite firmly on dash between the air bag and stereo which seemed to quell it. Gonna start removing items one by one to see if it stops - stereo(pcm), glove box, cup holder, speaker.
Any other suggestions - google not really thrown anything up?
Regards
Ian
Stoo.c
PostPosted: Wed Nov 07, 2018 4:55 pm    Post subject: Reply with quote
I thought the same and I changed loads of front suspension components recently and it totally transformed things and this rattle seemed to go but now its back.
02 996 C4S
91 CRX vtec turbo
01 986 Boxster S
Robertb
PostPosted: Wed Nov 07, 2018 4:56 pm    Post subject: Reply with quote
Rattles and squeaks are a rabbit hole... I ended up getting my daughter to sit in the back of my 4S and agreed to pay her if she hunted down two really annoying rattles!
Marky911
PostPosted: Wed Nov 07, 2018 5:05 pm    Post subject: Reply with quote
I might do this for the sake of £18.
I occasionally get a very light chattering from dash/screen area but only in cold weather. Worth a go then.
My old volvo is squeak free during summer but in winter the rear edge of the dash rattles and squeaks. It's funny the difference a few degrees of temp makes.
Paynewright - try pressing on the bottom corners of the passenger airbag. It sometimes rattles in the mounting frame. There's a fabric tape that wears through/comes off. It used to drive me mad in my GT3.
Also if you still have a centre console the two cubby hole trays vibrate against each other, especially if one tray is still the cd drawers. A bit of foam tape sorts it.
Might not the above be but it's worth a check.
PostPosted: Wed Nov 07, 2018 7:53 pm    Post subject: Reply with quote
Can i just add .. this fault used to be common as muc ! .. i still see the odd car with this .
OPC fix was the teflon tape fitted under the screen rubber but if the rope works then use that .
By Teflon then i dont mean plumbers tape .. something like this ..
https://www.ebay.co.uk/itm/virgin-skived-PTFE-self-adhesive-Teflon-tape-10-x-0-25mm-per-1mtr-/283245064665
Obviously i would use the Porsche tape so worth a call to get a price .
Its a chattering squeeking noise but only when it can flex .. so bumps cornering etc .
Jamesx19
PostPosted: Wed Nov 07, 2018 8:26 pm    Post subject: Reply with quote
Tee hee, like the use of family members to assist. I had my daughter pressing down and pulling up the clutch pedal while I was underneath the car bleeding the clutch system. Free of charge too!!
I started with a rattle coming from the passenger door side of the car. After a year of being driven potty by it I tracked it down to the tacky stuff on the door foam liner constantly sticking and unsticking in a small spot making a ticking noise.
As soon as I solved that, I suddenly noticed the dash creak/squeak/rattle/chatter which I'd never noticed before. DOH! frustrated
Now remarkably free of rattles. Just spent the day finishing off running in the engine around the EVO triangle, and roads about Bala, North Wales. Fantastic.
1998 C2 Manual
Dammit
PostPosted: Wed Nov 07, 2018 9:11 pm    Post subject: Reply with quote
Bang over bumps - sun-visor mirrors flapping up and down due to broken springs (new visors).
High frequency rubbing noise - little plastic covers in the ceiling light (removed, Copydex, refit).
Another high frequency noise- handbrake release button vibrating (replaced handbrake with Tequipment one).
General rattling noise - passenger airbag (packed passenger airbag out a little).
Constant squeaking - window rubbers have lost ***** (krytox lube).
Squeaking clutch - clutch bushings (not fixed yet!)
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Nov 07, 2018 9:22 pm    Post subject: Reply with quote
I have squeek squeek squeek squeek coming from somewhere in front of my clocks
Maybe this is it!
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
For the window creak .. use rain X .. crytox often smears the windows .. rather annoying .
Downside is rain X will wipe away .. you apply it and leave to dry but will have to reaply it when noise comes back .
Use on glass and the rubber where both touch .
Clutch squeek inside and booster spring .. outside and slave / clutch cover ... grease on the end of the slave cyl first as otherwise its a box out and a new clutch Sad
Cab roof locateing pins is another .. krytox them .. along with gummi fledge on the cab roof front seal .
Dammit
PostPosted: Wed Nov 07, 2018 9:24 pm    Post subject: Reply with quote
I also had a squeak from the front left over bumps, all new coffin arms fixed that.
PostPosted: Wed Nov 07, 2018 9:25 pm    Post subject: Reply with quote
Maybe this is it!
Always try pushing / pulling the clocks / panel to see if it stops .. several different fixes for this on a 997 so i assume the same for a 996 .. i know the base of the cluster can cause noises .. felt tape along the base is one fix .
Dammit
PostPosted: Wed Nov 07, 2018 9:44 pm    Post subject: Reply with quote
I've had a new clutch, and related new clutch parts, and replaced the helper spring/s, was told it was bushings as none of the work done had banished the Clutch Mouse. Be mildly annoying if the box had to come out again.
wasz
PostPosted: Wed Nov 07, 2018 9:53 pm    Post subject: Reply with quote
I had a squeeky creaky clutch. Porsche updated the 996 release arm and pivot with the 997 items of a different design, about £100 in parts. I also replaced the release bearing guide tube and slave cylinder. No more creeky clutch.
Dammit
PostPosted: Wed Nov 07, 2018 10:14 pm    Post subject: Reply with quote
You are quite right - 997 part number:
PostPosted: Thu Nov 08, 2018 8:17 pm    Post subject: Reply with quote
Interesting .. does the noise sound like its outside and from the back .. try with window or door open ..
Or is it inside ?
i listed the obvious points but there are a few others ..
That work was done with the engine out and fairly recently .. 6 monthes ish wasnt it ?
Or was it a while ago ?
