996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Stubbsy996
PostPosted: Sun Nov 04, 2018 1:35 pm    Post subject: 996t Turbochargers refurb Reply with quote
Had my 996t serviced by a renowned specialist in August at 71,679 miles. Their report included:
"Turbocharger cores corroded, and Bank 2 turbo has small hole in the core and bank 2 actuator rod broken after wastegate – Not causing an issue at the moment, but be aware that the car will require a turbo refresh in the future – To give you an idea of cost involved - To remove the turbos, fully refurbish, and refit with all new oil lines, check valves and heatsheilds is £4400+VAT"
Ouch!
There is no performance issue at present as the car still goes like a scolded cat!!
Just wondered if anyone has any thoughts on this before I go ahead and bite the bullet?
P911X50
PostPosted: Sun Nov 04, 2018 3:59 pm    Post subject: Reply with quote
As the actuator rod is broken. Are you receiving less boost?
Porsche 996 Turbo X50 with 9e exhaust,
BMW M6 V10,
Previous
Evo 4 with Evo 8 MR Engine 360 bhp - Road Legal Track car
Previous
MR2 Turbo 280 bhp - Road Legal Track Car
Stubbsy996
PostPosted: Sun Nov 04, 2018 4:13 pm    Post subject: Reply with quote
[quote="P911X50"]As the actuator rod is broken. Are you receiving less boost?[/quoten] No issues with boost level!
cheshire911
Estoril
PostPosted: Sun Nov 04, 2018 4:25 pm    Post subject: Reply with quote
Sounds like they will send them away to be refurbished.
Cost of new Turbos will be considerably more.
Its probably something you are going to have to bite the bullet on. If it was not for corrosion, there is a cheap workaround on broken actuator arm by welding it. But as you're into new Turbos probably go for 2x turbo refurb and the ancillaries quoted.
996 2002 X50 Turbo Manual
ok51mon
PostPosted: Sun Nov 04, 2018 5:21 pm    Post subject: Re: 996t Turbochargers refurb Reply with quote
Ouch!
Phone - AET Turbo or Universal Turbo these are both renowned turbo builders who regularly feature on Car SOS and Wheeler Dealers.
You'll be surprised by how inexpensive it is to have a set of K16 turbo's rebuilt back to OEM standard. Hybrid builds are a different story of expense..
Now, the remainder of that fee will be placed on labour of removing and replacing the 12 bolts (6 for each turbo) from the car.
The garage will probably say that the bolts will be corroded on (and they probably will be) and that what takes most of the remaining £3980 inc vat in labour to remove and replace those turbos.
There's is a lot of smoke and mirrors in the Porsche Indie world so just be sure you are clear and what job you are paying for.
If you have anymore questions feel free to PM me.
Alternatively Im happy to have an open conversation on here if it benefits others.
All the Best
S
*Amended for clarity and G&P bye
4.1L Incoming
996ttalot
Approved Trader
PostPosted: Sun Nov 04, 2018 7:49 pm    Post subject: Re: 996t Turbochargers refurb Reply with quote
Ouch!
Here is what I want you to do OP.
Phone - AET turbo's or Universal Turbo these are both renowned turbo builders who regularly feature on Car SOS and Wheeler Dealers.
You'll probably be surprised by how inexpensive it is to have a set of K16 turbo's rebuilt back to OEM standard. Hybrid builds are a different story of expense..
The garage will probably say that the bolts will be corroded on (and they probably will be) and that what takes the extra £3400 labour to remove and replace those turbos.
There's is a lot of smoke and mirrors in the Porsche Independent world so please ensure you are clear and understand exactly what job you are paying for.
All the Best
S
There is no smoke or mirrors in the Indy work Simon, just a proper way of doing it.
So you think £3400 in labour - really ?
£400 for each turbo refurb? I have yet to have any turbo refurbed back to new for even close to that - remind me how much a set of actuators are from Porsche ? Iirc they are £310 each, oil lines, vent lines , check valves , catch can are about £460 on each side alone never mind the turbos themselves.
When you replace a turbo you always replace all the lines because they are full of carbon deposits - seen a new turbo blow in 2 minutes at another independent who ignored my advice and tried to do it on the cheap. You leave those deposits in the lines and you reduce the life of the turbos.
As to 6 bolts - any decent place is removing the manifolds and replacing all the bolts at the same time.
Then boost leak, datalogging and testing after installation.
It is what Porsche do when they resolve except they charge £9200 plus vat and we charge £4400 plus vat.
There is a cheap way and a proper way.
nineexcellence.com
Tel: 01293 226911. Follow us on Facebook www.facebook.com/Nineexcellence
SALES, SERVICE, UPGRADES
cheshire911
Estoril
PostPosted: Sun Nov 04, 2018 9:16 pm    Post subject: Reply with quote
Well said Ken! The last sentence says it all.
plynchy
PostPosted: Sun Nov 04, 2018 10:43 pm    Post subject: Reply with quote
Before I found my car I test drove a black 996T in North London that pulled like an absolute lunatic. It was re-mapped to some degree.
Back at the chaps works car park I pulled my overalls and jack out of my boot to have a nosey underneath , I found the N/S actuator rod snapped, so the car was still pulling very well, albeit stressing one turbo to death whilst the other did no graft whatsoever. Very surprised to say the least, so was the seller. Goes without saying, I don't own a black car.
'02 996 Turbo Manual Coupe Lapis/Grey. Unlimited grins.
ok51mon
PostPosted: Sun Nov 04, 2018 11:17 pm    Post subject: Re: 996t Turbochargers refurb Reply with quote
996ttalot wrote:
Ouch!
All the Best
S
Ken, I don't agree.
In the interest of diplomacy I won't be commenting on the other points you made either I'm afraid.
4.1L Incoming
ok51mon
PostPosted: Sun Nov 04, 2018 11:34 pm    Post subject: Re: 996t Turbochargers refurb Reply with quote
Ouch!
It may be worth mentioning that the opinions I've given is not individual but a shared one.
When I had my OEM turbo's rebuilt with genuine components they were around £650 inc vat each iirc
All the best
S
4.1L Incoming
bakerboy4s
PostPosted: Mon Nov 05, 2018 8:34 pm    Post subject: Reply with quote
GNot looking to stir things , just had quick look at AET site, service exchange K24 turbo, £795 each presume + vat.
So as 9e says with all the other ancillary parts and labour and vat your gonna struggle for a' cheap' job! assuming they are needed.
ok51mon
PostPosted: Mon Nov 05, 2018 9:50 pm    Post subject: Reply with quote
I bought my first Rolex with my savings bye
4.1L Incoming
 Filesize:  1.51 MB
 Viewed:  1242 Time(s)
lofi
2001 Porsche 996 Turbo
PostPosted: Tue Nov 06, 2018 7:24 pm    Post subject: Reply with quote
why is the watch bracelet covering the part description?
LoFi
996 turbo tip
ex 944 2.5 manual
ex 964 C4 manual
ok51mon
PostPosted: Tue Nov 06, 2018 9:28 pm    Post subject: Reply with quote
Thanks for all the nice pm's guys.
For the few that asked, the labour work was commenced at Porsche's Head Office hence why the return/send address is Porsche RG (good eye!).
Happy to put up their labour invoice but be warned it's cheap ....
Conclusively, there is a cost effective way that is proper which includes being advised by Porsches Workshop Manager and Head Technician every step of the way.
They actually have a department dedicated to the older car not under warranty.
In this department the labour price is deliberately lower for cars 10+ year old (please correct me on this as this is an approx) to £105 per hour inc vat iirc. Usually its something ridiculous like £185 plus vat.
All the Best
S Thumb
4.1L Incoming
996ttalot
Approved Trader
PostPosted: Tue Nov 06, 2018 10:14 pm    Post subject: Reply with quote
All the Best
S Thumb
Simon
Why don’t you put up the whole job showing all the parts and labour so everyone can you what you have had done.
Then I will do the same - you only need to show one turbo.
I am sure everyone will be interested
Ken
nineexcellence.com
996ttalot
Approved Trader
PostPosted: Tue Nov 06, 2018 11:01 pm    Post subject: turbo refurb Reply with quote
Here is ours.
nineexcellence.com
9E 996T T REFURB.pdf
Download
 Filename:  9E 996T T REFURB.pdf
 Filesize:  41.35 KB
 Downloaded:  93 Time(s)
plynchy
PostPosted: Tue Nov 06, 2018 11:11 pm    Post subject: Reply with quote
£400 for one actuator?? Floor
And I thought the oil industry took the piss.........no offence Ken as I realise these are Porsche prices.
996ttalot
Approved Trader
PostPosted: Tue Nov 06, 2018 11:18 pm    Post subject: Reply with quote
yes it is a joke from Porsche for sure - we buy direct from bw and it is not as bad. Those parts like the lines used to be half that price 3-4 years ago but Porsche worked out that 996 turbo was good market - same has happened with 997 turbo now - all the lines have gone up crazy price Mad
nineexcellence.com
ok51mon
PostPosted: Tue Nov 06, 2018 11:59 pm    Post subject: Reply with quote
My objective in this thread is to share information for the best interest of a other Porsche owners in an as unbiased manner as possible.
-Not to turn threads into a versus match or argument.
-Not to defame an individual(s) or company (s).
Unfortunately, you have put yourself and your company in a difficult position by taking ownership of the quote that the initial user posted of which no names were mentioned initially.
I won’t be putting up the Porsche’s conclusive invoice for you to try and compare you’re service to as I have no interest in embarrassing anyone on a public platform should there be a possibility of doing so
If people are motivated they will simply contact both companies for comparative quotes.
Which I encourage.
These platforms are for helping everyone out.
My advice to you would be to alter your initial post and take down the accountability of the thread starters quote.
I’d also recommend removing the indirect pun about my approach that was facilitated by Porsche Head office taken being cheap and not ‘proper’.
All The best
Si Thumb
4.1L Incoming
996ttalot
Approved Trader
PostPosted: Wed Nov 07, 2018 12:54 am    Post subject: Reply with quote
The facts are that the quote from the OP was text copied from an email from 9e to the OP.
You have then deduced ( how we would all like to know ) that the Labour was close to £4k, that ( and quite rightly the OP ) should shop around because of the labour. Unfortunately as has been shown by our internal document, the labour is not £4K.
The problem Simon is the OP may based on your comment believe we are ripping them off. I am entitled to defend 9e.
You then say that you don’t want to argue, not your intention to deflame etc and yet in the next sentence say you wont put up as you don’t want to embarrass us ? So you are still trying to make a point that we are not providing a good price.
So you have the list , you have the labour and what is changed. So unless you are paying less than £80 plus vat per hour , or you are not doing xyz as detailed in the labour, the only difference in price will be if the turbo refurb is cheaper.
The point of the forum is to help others and make them informed. Your saying £2200 plus vat is a rip off for one turbo refurb. Your saying that Porsche OPC will do it cheaper.
Well show us how that is please and if you can then I will be happy to adjust my pricing.
I am not taking any post down Simon. My post stands.
Ken
nineexcellence.com
Goto page 1, 2, 3  Next
Page 1 of 3
