996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
steve r
PostPosted: Fri Nov 02, 2018 12:20 pm    Post subject: Help with part numbers for Clips? Reply with quote
Can anyone help with the part numbers for these clips please.
One is a plastic clip that holds 2 slightly different sized hoses together under the car and the other is a metal clip that goes into a square/ractangular hole in a bracket under the car which a screw for one of the under trays goes into.
40th Anniversary
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Nov 02, 2018 1:48 pm    Post subject: Reply with quote
The latter is a "speed nut"
I bought a bag full of stainless ones and stainless screws to go with them years ago and have replaced cruddy ones all over my 996 when doing jobs.
EDIT: now I think about it that gearbox mount speed nut is different as it clips in the square hole I think. Can't remember now what I did here as mine was missing. I think I just held a speed nut over the hole and screwed the screw in before fixing the rest of the under tray. Not perfect. I need one too then if you find a part number!
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
Pickse
PostPosted: Fri Nov 02, 2018 8:03 pm    Post subject: Reply with quote
Deroures has some good parts diagrams
https://www.deroure.com/diagrams.asp?MDL=25&MAK=3&SMA=0&SMO=0&ST=&SC=0
Pickse
2003 Arctic Silver 996 Turbo Tiptronic S
PostPosted: Fri Nov 02, 2018 8:56 pm    Post subject: Reply with quote
Ive searched that site and pet .. it seems the speed nut is part of the bracket and is not sold seperatly .. ive found something similar but have no idea if it will work .. no. 13
pipes and 19 numbers are pipe sizes ?
no idea if these are correct but its all i can do .. i tend to fix cars and not find parts Sad
Images below ..
 Filesize:  262.72 KB
 Viewed:  623 Time(s)
 Filesize:  82.43 KB
 Viewed:  623 Time(s)
 Filesize:  195.63 KB
 Viewed:  623 Time(s)
 Filesize:  85.26 KB
 Viewed:  623 Time(s)
steve r
PostPosted: Fri Nov 02, 2018 10:20 pm    Post subject: Reply with quote
Thanks for the help.
I found part. Number 999 507 488 40 for the plastic clip so have ordered one of those and will see if it’s right.
Not luck either with the metal but. I’ve got some of the slip on ones but this clips into the bracket. The Porsche PET got the undertrays suggests one of the plastic expanding rivets is used but that’s a round fasterner in a square hole....
In my VW days their parts catalogue ETKA had a section with drawings of most of the different fasteners. I’ll see if I can find a copy of it & have a search.
40th Anniversary
steve r
PostPosted: Tue Nov 06, 2018 7:59 pm    Post subject: Reply with quote
999 507 488 40 was a good number for the plastic clip. It was closed up out of the packet and felt like it would break when i tried to open it a little so i heated it up infront of my fan heater and it clipped on nicely.
Now to track down the speed nut that clips into the square hole.......
40th Anniversary
