997 : 2004- 70
964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 4
hopeydaze
PostPosted: Thu Nov 01, 2018 1:25 pm    Post subject: 993 gear change when cold Reply with quote
I ventured north to the PCGB trackday at Oulton Park yesterday. I stayed at a local hotel the previous night and woke up to a cold morning and a gearbox that refused to go into gear, and when I eventually found 2nd it stayed there until I got to the track. Once warm, the gearbox was flawless, and the car was great on track.
I haven't heard of this problem before and have never seen it mentioned on the various 993 forums...and then I did a search on here to find it was widely discussed 10 years ago with the famous Baz from Hartech advising on changing gearbox oil and not to use additives. Others recommended letting the engine warm up for 10 minutes.
Presumably, the reason I haven't heard of this issue is because no-one drives their 993 in winter?javascript:emoticon('Laughing')
P.S. loads of 991 GT3s on track - and they are too fast
P.P.S. - instructor asked if I had considered M030 sports suspension. Any thoughts?
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Thu Nov 01, 2018 1:33 pm    Post subject: Reply with quote
I don't remember my 993 ever being that problematic when cold. A little stickier as all manual cars generally are, but all gears available. A gearbox oil change certainly won't do any harm.
Best practice generally is to start and drive off straight away (but driving gently) as the engine and transmission will warm up faster and hence wear less. Presumably if the car is not moving then the gearbox oil won't warm up.
M030... have a drive of a car with it. What works well on a track may not be ideal for road use. Default advice is to get along to Centre Gravity and have them fit recommended parts set the car up for you, based on what you want.
Tobesetc
PostPosted: Thu Nov 01, 2018 5:46 pm    Post subject: Reply with quote
Slightly off topic, this reminds me of a question I had: We are commonly advised not to let the car warm up standing still, but to drive it, as the oil pump doesn't circulate oil until the engine is warm and fires the thermostat. But the same is true regardless of whether the car is moving or static. Is the advice solely based on the idea that the motion of the car circulates the oil?
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
kas750
Reims
2006 Porsche 911
PostPosted: Thu Nov 01, 2018 6:04 pm    Post subject: Reply with quote
The engine will warm more quickly when under load being driven rather than sat idling and hence not under as much strain.
Albionmuz
PostPosted: Thu Nov 01, 2018 6:07 pm    Post subject: Reply with quote
Mine needs very sympathetic changes from 1st to 2nd until it warms up in the winter, it’s fine in all other gears though. Once warm no problems in any gear.
993 Targa manual
Alfa GTV Twinspark
Citroen Deux Chevaux
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
Endoman
PostPosted: Thu Nov 01, 2018 9:50 pm    Post subject: Reply with quote
The spigot bearing may be dry, that's the bearing in the middle of the flywheel not an easy job to replace.
When the clutch is engaged the input shaft to the geaxbox is still spinning with the engine, making it stiff to engage 1st and 2nd or even stick ingear.
One of those while the clutch is changed jobs.
When you are rolling it's a lot easier to get in the higher gears, on a bike you can change gears without the clutch when moving and I've done it in a car when the clutch slave cylinder failed (not recommended).
Porsche recommended transmission oil is supposed to improve gearchanges but it's very expensive.
A slave cylinder bleed would be the first thing to look at though, if the fluid looks like treacle then a fluid change may help.
decgraham
PostPosted: Fri Nov 02, 2018 7:42 am    Post subject: Reply with quote
Oh the joys of the Tiptronic S, no gear change issues for me, smooth as silk Very Happy
ATB Smile
Will Statt
PostPosted: Fri Nov 02, 2018 8:22 am    Post subject: Reply with quote
Ha... our engines wouldn't last long if that was the case! The oil pump works whenever the engine is turning. The only difference is that when cold, it only circulates the lesser amount of oil in the crankcase, and the full volume of oil is only circulated when the engine warms up a bit and the thermostat opens the valve to the oil reservoir. That way the engine warms up quicker, as it's only initially 'warming' a small amount of oil!
Smile
2014 Porsche Boxster 981
PostPosted: Fri Nov 02, 2018 8:33 am    Post subject: Reply with quote
Something is not right you should be able to change gear easily in all temps Thumb
"Great spirits have always encountered opposition from mediocre minds" Einstein
#lastoftheaircooled
2014 Porsche Boxster GTS My Journal
Cameltoe & Heel
PostPosted: Fri Nov 02, 2018 8:44 am    Post subject: Reply with quote
Yes oil pump works all the time as driven directly from the crank, otherwise a huge issue.
So first port of call here is your gearbox oil, do you know what's already in it?, and when it was last changed?, this is a basic question to everyone that owns a 993 and if you don't know the answer then you NEED to change your gearbox oil, i know and have had the great expense of dealing with the results of not changing the oil enough (not me but previous owners). Your gearbox is incredibly complex an if it wears or worst fails then you have a problem.
Porsche quote something silly in our service book for gearbox oil change, something like 50k miles and doesn't mention time. Like I say care for your box, your wallet will thank you for it.
Trev
hopeydaze
PostPosted: Fri Nov 02, 2018 9:20 am    Post subject: Reply with quote
I read on the posts from 10 years ago about fully lifting the clutch pedal by hand and that somehow this makes it easier to change gear from cold. I tested it this morning (very cold and had to scrape ice off windscreen). Gear change was easy.
Agree with Endoman about bleeding the clutch.
Will Statt
PostPosted: Fri Nov 02, 2018 10:00 am    Post subject: Reply with quote
They do seem to vary a lot, and it's not unique to Porsche to be 'stiff when cold' Very Happy Other agricultural vehicles... tractors, land rovers etc are the same!
I'm lucky... mine is easy cold or warm. Part of the charm of these 'old' cars!
johne
PostPosted: Tue Nov 06, 2018 8:32 pm    Post subject: 993 gear change when cold Reply with quote
I had a problem with my gear shift on some of the long bends at Silverstone .I hadn't had the car long .and perhaps I was trying to rush the gears .after putting fresh gearbox oil in ive never had the same problem
nickjonesn4
PostPosted: Tue Nov 06, 2018 9:27 pm    Post subject: Reply with quote
Hi there
I had exactly the same issue with my car. When it went in for a diff to be fitted RPM found the gearbix oil was filthy and various bits and pieces were worn as a result and needed replaced. You can see what I am talking about here http://www.911uk.com/viewtopic.php?t=124270&postdays=0&postorder=asc&start=60
Nick
1996 Carrera 2S Vesuvius Metallic
2016 Golf R
2005 E55K Wagon
