996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
APL911
PostPosted: Sat Oct 27, 2018 11:14 am    Post subject: Low speed turning tyre scrub/ understeer Reply with quote
Hey.
I’ve noticed recently that my 991.1 does something odd when manoeuvring at slow speeds in car parks etc.
When driving forwards and turning sharp left or right, the front tyres judder and understeer slightly. Like they are skipping over the road surface.
This is at crawling speed only. It never happened on my 996.
It’s got 20” carrera s wheels, PASM -10mm, Manual transmission and done 47k Miles.
Has anyone else seen this? I’m concerned (as usual) that my car may have an issue?
pzero
PostPosted: Sat Oct 27, 2018 11:36 am    Post subject: Reply with quote
A quick search returned this;
http://911uk.com/viewtopic.php?t=91102&highlight=&sid=f5389e4b7199a7042f952ee03c03b5a4
991.1 Carrera GTS
6appeal
PostPosted: Sat Oct 27, 2018 1:32 pm    Post subject: Reply with quote
yes its completely normal. no issue.
Present:
991.2 Carrera, SC, PDK, Toys Smile
Yamaha MT01
VW T2 Bay Window 1976
Past:
640d GC, 635d Coupe, RS6 C5, Audi TT 225 Coupe, Astra with wind up windows, Citroen ZX, Rover 213, yes behold, a Rover 213... Renault 5
Kryton
PostPosted: Sun Oct 28, 2018 9:50 am    Post subject: Reply with quote
I've owned three 991's (.1 C2S, .2 C4S Targa, .2 GT3.) and they've all scrubbed their tyres as you describe OP
991.2 GT3, full Club Sport pack
2019 Macan (weekday drive)
MaxA
PostPosted: Mon Oct 29, 2018 7:59 am    Post subject: Reply with quote
I have this. It's worse in the cold. Until I swap to winter tyres at least...
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
mr pg
PostPosted: Mon Oct 29, 2018 8:13 am    Post subject: Reply with quote
Notorious on 981's, but almost disappeared on mine since going from P zeros to Michelin PS4PS.
tim993
2016 Porsche Boxster 981
PostPosted: Mon Oct 29, 2018 11:53 am    Post subject: Reply with quote
yep - exactly as I found on our old 981. I thought perhaps the limited slip diff, might have contributed to this scrub Dont know
"I don't know what it is about peace conferences, but they always seem to attract terrorists, extremists and nutterists."
1995 993 turbo
Rob325114
PostPosted: Mon Oct 29, 2018 12:37 pm    Post subject: Reply with quote
Yep - I have this when the car is cold, and it's cold outside. Goes away once the tyres are warm, or the weather improves.
I did some searches when i first noticed it, and found it to be normal.
Current: Agate Grey 991.1 C2S Coupe, PDK
Ex: Black 997.1 Hartech'd C2S Cab, manual
Ex: Silver Citroen C2 GT, manual
Ex: Blue Ford Fiesta Zetec S 1.6, manual
Gottans
PostPosted: Mon Oct 29, 2018 6:14 pm    Post subject: Reply with quote
I believe it is related to the suspension geometry, my Audi also does it and worse in the cold or when tyre tread depth is low as the tread blocks are stiffer.
PostPosted: Mon Oct 29, 2018 8:24 pm    Post subject: Reply with quote
I agree with everything above and so will just say dont worry about it .
matt_SM
PostPosted: Tue Oct 30, 2018 12:25 pm    Post subject: Reply with quote
Cold tyre scrub is not unique to the world of Porsche - plenty of modern cars with wide (performance bias) rubber will do this. The scrub becomes more obvious at this time of year because the temperature drops and the road becomes more greasy.
Whilst manoeuvring at low speed the outside tyre will scrub in a comparable way to slip angle on a track day.
We have an 'L' shaped driveway and both of our dailies have started to do this again as winter beckons.
Matt
2004 GT3 Clubsport, speed yellow
Martin Rose
PostPosted: Tue Oct 30, 2018 5:57 pm    Post subject: Reply with quote
I had a 981 as a courtesy car from OPC Colchester. Couldn't believe the noise when turning in the car park and went back inside to tell them something was wrong with the car. "They all do that sir" was the reply. Personally I couldn't live with that.
Martin R
997 C2S Gen 2
Cayenne GTS
ex - 987 Boxster Spyder
ex - 993 turbo
ex - 993 C2S
