997 : 2004- 67
Boxster : 1997- 20
Cayman : 2005- 14
Mezgerite
PostPosted: Fri Oct 26, 2018 2:59 pm    Post subject: Under body panel part no. Reply with quote
I can't find the broken part in the parts diagrams, anyone know what it is?
Thanks!
 Filesize:  683.75 KB
 Viewed:  1537 Time(s)
PostPosted: Fri Oct 26, 2018 4:16 pm    Post subject: Reply with quote
No 1 here is the front arch liner ..
https://www.deroure.com/diagrams.asp?TBL=2860&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
Is it just the plastic bit thats broken or is the rad support also damaged ?
Mezgerite
PostPosted: Fri Oct 26, 2018 5:04 pm    Post subject: Reply with quote
thanks!
I looked at the arch liner but it didn't look the right shape on the diagram compared to my picture!
It's just the plastic part that is damaged. Does the rad need to come out for this to be replaced?
Rick
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Fri Oct 26, 2018 5:09 pm    Post subject: Reply with quote
Great link, thanks DeMort
PostPosted: Fri Oct 26, 2018 5:38 pm    Post subject: Reply with quote
Mezgerite wrote:
thanks!
Rick
nope .. its a handfull of torx screws but it is a bit of a fiddle getting it out .. pull the bumper outwards whilst pushing the liner inwards.
I thought the rad support might be damaged as the bumper is cable tied instead of the screw .
I think you might also be missing a center air scoop ... has it got a center rad ? if so then you are but it doesnt matter that much to be honest .
Mezgerite
PostPosted: Fri Oct 26, 2018 5:52 pm    Post subject: Reply with quote
OK great, that will b ordered. It is missing the centre air outlet, I'm ordering that too. Does that need any hardware, I'l need to order that too.
Not sure why the bumper is tie wrapped, it might just be that fixing hardware on that went AWOL so will need to order too!
Rick
PostPosted: Fri Oct 26, 2018 6:29 pm    Post subject: Reply with quote
The rad support has a pushed in speed clip for the screw to fasten onto .
Youll need a T 25 / T30 screwdriver or socket attatchments for the screws .
Center air scoop just kinda clips in place into the bumper .. youll soon figure how all these bits fit .. its pretty straight forward .
If not a picture and an email here for directions ..
De.Mort@virginmedia.com
No replys untill the evening though as thats the only time i log on my computer .
Mezgerite
PostPosted: Fri Oct 26, 2018 8:30 pm    Post subject: Reply with quote
Thanks for info, very much appreciated.
Need to order some insets i think.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Oct 26, 2018 10:18 pm    Post subject: Reply with quote
I keep breaking my front arch liner/brake cooling scoop as my car is so low, the front part (as yours has) breaks off every so often, I just buy a used one online as the new ones are around £60 to replace each time and a used one will only get damaged again at some point and its unseen.
Mezgerite
PostPosted: Thu Nov 08, 2018 8:46 pm    Post subject: Reply with quote
deMort,
Rear cover, number 7 - it uses clips - that fit into the chassis. In the chassis they are inserts pressed in. I ordered no 8 in the diagram but it's not those, No 8 are a totally different shape. Do you know if the inserts are part of another diagram?
Thanks!
https://www.deroure.com/diagrams.asp?TBL=2859&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
IMI A
PostPosted: Fri Nov 09, 2018 1:34 pm    Post subject: Reply with quote
Hi Rick hope you're well buddy. I think the turbo and carrera wheel arch liners may perhaps be different? Keep well thumbsup
https://www.deroure.com/diagrams.asp?TBL=3543&MAK=3&MDL=29&SMA=0&SMO=0&ST=&SC=0
PostPosted: Fri Nov 09, 2018 7:04 pm    Post subject: Reply with quote
Trying to find it .. hmm ....
As far as im aware the rear panel screws into 8 and 10 here but there is nothing listed for that part .. ive checked Pet as well .. nothing listed .. so either im useless .. very possible .. or they are not seperate items .. i think an OPC might be your best bet im afraid . ... im just a mechanic Sad
https://www.deroure.com/diagrams.asp?TBL=2822&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
Mezgerite
PostPosted: Fri Nov 09, 2018 7:51 pm    Post subject: Reply with quote
Thanks, will give OPC a call but i don't hold out much hope. Might have to make something.
Mezgerite
PostPosted: Fri Nov 09, 2018 7:54 pm    Post subject: Reply with quote
I think this is the part, looking from the top you can see the top of 3 clips.
PostPosted: Fri Nov 09, 2018 8:08 pm    Post subject: Reply with quote
need the link young man Smile
