997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
Jack D
PostPosted: Tue Oct 23, 2018 7:43 pm    Post subject: Odometer repair Reply with quote
Stripped the speedo down to replace the small gear today, easier than I thought it would be.
There is no need to remove the needle from the dial, once the bezel and rear case is off, everything is doable from there, just be aware that the front is delicate so care is needed to prevent damage to the needle and face of the dial.
There is a great video on utube on how to do this job.
Jack D
Cameltoe & Heel
PostPosted: Wed Oct 24, 2018 7:56 am    Post subject: Reply with quote
Thanks for the tips Smile
Trev
pietrzj
PostPosted: Wed Oct 24, 2018 6:59 pm    Post subject: Reply with quote
any tips on how to get the glass off? I have a film of crap behind mine, but don't want to damage the bezel
Jack D
PostPosted: Wed Oct 24, 2018 7:58 pm    Post subject: Reply with quote
The only way of getting the glass out is to remove the bezel, this isn’t difficult but you need to take your time so not to damage the bezel, it is quite fragile so you really need to take your time on this.
You need to gently prise up the back of the bezel, I used a small electrical screwdriver and slowly worked around the bezel teasing up the back part of the lip until it’s loose enough to take off, don’t try and lift the lip in one go but carry on slowly working around the unit.
Replacing the glass and bezel I put the unit face down on a hard surface and used a small piece of plastic trim to push the lip of the bezel back down, again working slowly around the unit several times until it was a snug fit.
Link below is of the repair, you may have to copy and paste the link to open
http://youtu.be/71MKmTKATgo
Jack D
grahampm
1997 Porsche 911
PostPosted: Sun Nov 11, 2018 8:12 pm    Post subject: Reply with quote
Looks straight forward enough - just being methodical!! Where did you buy the replacement gear wheel from.
TIA
Graham.
Bona fide Porsche nut! With petrol in my veins!
1997 - 993 Speedster
2017 - Macan S
2018 - 991.2 GT3
2018 - i8 Roadster
Jack D
PostPosted: Sun Nov 11, 2018 8:37 pm    Post subject: Reply with quote
I thought it was straightforward enough, like you say just be methodical.
I bought the gear from design911, I thought they took the p#ss on delivery charges of £5, and made a point of telling them !
I think it was £40 Incl del.
Do a search online, you may find it cheaper.
Regards
Jack D
Jack D
PostPosted: Sun Nov 11, 2018 8:53 pm    Post subject: Reply with quote
I think I read somewhere that there is a variation in the number of teeth on the gear, mine is a tiptronic and has 15.
I took the speedo apart before ordering the new gear wheel.
Regards
Jack D
decgraham
PostPosted: Mon Nov 12, 2018 7:49 am    Post subject: Reply with quote
I used this guy to repair mine, hassle free and a good job. No affiliation.
https://www.ebay.co.uk/itm/Porsche-911-VDO-Electronic-Speedometer-Repair-SERVICE-930-993-964-944-928/332599502015?hash=item4d7079a4bf:g:mSMAAOSwnDZUEG-O
ATB Smile
Jack D
PostPosted: Mon Nov 12, 2018 11:39 am    Post subject: Reply with quote
If that’s the total cost with the gear wheel, then that’s a very good deal.
I was quoted nearly 3 times that by specialists, hence doing it myself.
Jack D
stevewak
PostPosted: Mon Nov 12, 2018 3:39 pm    Post subject: Reply with quote
ATB Smile
100% agree. He is good.
1995 993 Carrera 2 Slate Grey/Marble Grey + Black
2002 BMW 330i Touring
cableguy
PostPosted: Mon Nov 12, 2018 8:29 pm    Post subject: Reply with quote
Jack D
It's the Porsche TAX, not applicable to any other marque!
C.
Pork!
