996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
Endoman
PostPosted: Sat Jan 05, 2019 5:57 pm    Post subject: Reply with quote
Yet another caught in time.
Cheers Diddi
 Filesize:  149.4 KB
 Viewed:  664 Time(s)
 Filesize:  106.09 KB
 Viewed:  664 Time(s)
 Filesize:  165.08 KB
 Viewed:  692 Time(s)
Cameltoe & Heel
PostPosted: Mon Jan 07, 2019 8:40 am    Post subject: Reply with quote
Oh dear, that belt's seen better days Surprised
Good work getting this sorted.....
Trev
Endoman
PostPosted: Tue Jan 08, 2019 1:14 pm    Post subject: Reply with quote
New ecu (don't ask). MPL and remote clutch bleed (highly recommended) custom made pipe by HAL 7mm banjo fitting with bulkhead fitting at other end for bleed nipple. It will be attached to l/h side of inlet manifold with a custom angle bracket.
Resonance flap seal and gasket replaced, lubed with Molykote.
 Filesize:  139.75 KB
 Viewed:  553 Time(s)
 Filesize:  155.64 KB
 Viewed:  553 Time(s)
 Filesize:  211.73 KB
 Viewed:  553 Time(s)
Dom B
1996 Porsche 993 Carrera 4S
PostPosted: Tue Jan 08, 2019 6:34 pm    Post subject: Reply with quote
Great work Thumb
Love the remote bleed idea. I've had an MPL sat in the garage for years, I must get round to fitting it at some point.
Endoman
PostPosted: Thu Jan 10, 2019 6:41 pm    Post subject: Reply with quote
Dizzy is back and looks great the old belt was very brittle and snapped at the merest tug. I should have taken notice of the warning about DHL as I had to go to their depot to pick it up. Their web site needs sorting and the phone help is non-existant it took ages to find out where the parcel was.
They have been good in the past but I asked for it to be dropped off at a collection point in the village ,listed by DHL but no longer dealing with them, and I had no way of changing the delivery.
 Filesize:  185.54 KB
 Viewed:  438 Time(s)
Cameltoe & Heel
PostPosted: Fri Jan 11, 2019 9:16 am    Post subject: Reply with quote
Ahhh this is good work Diddi here, good job you switched that belt John.
I love the remote bleed idea, I have the job of bleeding my clutch soon and I'm hoping that gravity will help me Smile.
Trev
Endoman
PostPosted: Fri Jan 18, 2019 6:07 pm    Post subject: Reply with quote
Turned the corner. Engine is back in and I've now got heat in the garage.
No not from the engine, a propane heater from Machine Mart.
Still a lot to do but should be able to fire her up tomorrow.
Clutch bleed attached to manifold unfortunately a bit more difficult if you still have the rear blower. I fed the flexy though an extra hole in the grommet that takes the crank sensor wire.
It's quite tricky getting the engine back in single handed especially at the front manouvering around the clutch pipe.
 Filesize:  141.24 KB
 Viewed:  190 Time(s)
Tycho
1995 Porsche 993 Carrera 2
PostPosted: Sat Jan 19, 2019 6:08 pm    Post subject: Reply with quote
Who did you you use to send your dizzy? This is my next job & I am working on a schedule.
Chris
Endoman
PostPosted: Sat Jan 19, 2019 6:41 pm    Post subject: Reply with quote
I sent the dizzy to Diddi, D964@gmx.de via DHL the problem was getting it back as the drop off was no longer handling DHL parcels. It's an occasional problem with no one in at home and funny working hours. Normally DHL is fine, but I would keep way from Parcelfarce.
Diddi's turnaround is very quick this is the 3rd one I've sent to him.
Just drop him an email.
Endoman
PostPosted: Sat Jan 19, 2019 6:49 pm    Post subject: Reply with quote
The nonvram breather pipe from the crank case is a bit shorter than the vram one but £127! I'll bridge it with some aluminium tubing. I've forgotten the routing of the throttle cable so Trev is kindly sending me a photo of his.
All these little things are taking up a lot of time.
Goto page Previous  1, 2, 3, 4, 5
Page 5 of 5
