997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 17
nickjonesn4
PostPosted: Sun Oct 21, 2018 1:00 pm    Post subject: Dashboard LEDs Reply with quote
Afternoon all, hope nice weekend's are being had
Has anyone fitted these?
https://www.design911.co./mobile/#part;id=135270uk
Or these
https://www.design911.co.uk/mobile/#part;id=135269
Finding the dullness of the instrument lighting a real pain as doing a lot more miles in the dark recently and these look like a good solution. Has anyone fitted and any preference over the bright or "vintage"?
1996 Carrera 2S Vesuvius Metallic
2016 Golf R
2005 E55K Wagon
Sutton
PostPosted: Sun Oct 21, 2018 2:03 pm    Post subject: Reply with quote
I got mine from Superbrightled.com.
Per Tore B, the airbag bulb has to remain as an incandescent bulb otherwise you'll trigger an airbag fault warning.
1994 993 C4
nickjonesn4
PostPosted: Sun Oct 21, 2018 3:50 pm    Post subject: Reply with quote
Thx
2016 Golf R
2005 E55K Wagon
mashby
PostPosted: Sun Oct 21, 2018 4:43 pm    Post subject: Reply with quote
Are you sure it's not just some of the original bulbs have gone. I've recently replaced all my instrument bulbs with original spec bulbs and they seem more than bright enough.
1994 993 C2
1974 MGB GTV8 3.5
1980 MGB Roadster 1800 stage 3
 Filesize:  1.34 MB
 Viewed:  2236 Time(s)
nickjonesn4
PostPosted: Sun Oct 21, 2018 5:16 pm    Post subject: Reply with quote
Could be I suppose, however I do find them a bit dim
2016 Golf R
2005 E55K Wagon
Nik
PostPosted: Sun Oct 21, 2018 9:05 pm    Post subject: Reply with quote
Do you have a list of the bulbs that are needed ?
Sutton
PostPosted: Mon Oct 22, 2018 3:41 pm    Post subject: Reply with quote
Hi Nik
If you're doing just the backlights for the five instruments, then 11 white bulbs will be fine. If you want to do the HVAC panel as well, then you'll need another 2 bulbs.
For the warning lights in the various instruments, you'll need:
4 x amber
4 x green
1 x blue
13 x red
The leds are polarity sensitive, so you may need to take them out and rotate 180 degrees if they don’t work first time.
I'm clumsy and broke some so I had bought spares for that eventuality. The friction tabs are deliberately loose to enable fitment to any thickness of circuit board - you need to bend them about 45 degrees to get enough friction to engage the circuit board.
1994 993 C4
ch3tman
1995 Porsche 911
PostPosted: Mon Oct 22, 2018 4:23 pm    Post subject: Reply with quote
Just to check, have you turned up the dial to control dashboard light strength? When set to maximum, I find my incandescent bulbs more than adequate.
Photos | instagram.com/ch3tman
For Sale | OEM 17" Cup II Wheels + Tyres
nickjonesn4
PostPosted: Mon Oct 22, 2018 9:33 pm    Post subject: Reply with quote
Yep!
2016 Golf R
2005 E55K Wagon
nickjonesn4
PostPosted: Mon Oct 22, 2018 9:34 pm    Post subject: Reply with quote
Sutton wrote:
Hi Nik
4 x amber
4 x green
1 x blue
13 x red
This is super useful thanks. Do you have a link for one of the relevant bulbs?
Amusingly I used the design911 chat app to ask what bulbs were in the pack and what they were for today... their answer was
"12 led bulbs"
Floor Floor
2016 Golf R
2005 E55K Wagon
Sutton
PostPosted: Mon Oct 29, 2018 5:00 pm    Post subject: Reply with quote
Hi Nick,
Here's the link.
https://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/b8-led-bulb-smd-instrument-panel-led-car/223/
You need the 8.4d version.
There's a choice of colour temperature too. Getting the tach out was a pain. The other guages were simple.
1994 993 C4
nickjonesn4
PostPosted: Tue Oct 30, 2018 1:16 pm    Post subject: Reply with quote
Sutton wrote:
Hi Nick,
Here's the link.
Awesome, thanks v much Thumb Thumb
2016 Golf R
2005 E55K Wagon
Citori
1996 Porsche 993 Carrera 2
PostPosted: Wed Nov 21, 2018 7:01 am    Post subject: Reply with quote
Hello.
I replaced the incandescent lamps in my dials with LEDs.
After much research and buying of different types I ended up with the result below.
The light is slightly whiter than the standard bulbs and the dimmer still works ok.
I also replaced the lamps in the climate control unit (uses the same lamps) and the center console, although this uses different LEDs altogether that have to be soldered in.
To get the right LEDs that fitted properly (type B8.5D) I had to buy a batch of 200. I still have some left if you are interested. They were advertised on this very site many moons ago.
The only problem is; I now live in Greece and won't be back in the UK until just before Christmas. Drop me a PM if you are interested in some.
http://911uk.com/viewtopic.php?t=86019&highlight=
Previously enjoyed Porsche:
1996 C2 Coupe.
1983 911 Carrera Targa Sport.
1981 911SC Sport.
1978 911SC.
1970 911E.
I have CDO. It’s like OCD, but the letters are in alphabetical order, LIKE THEY ARE SUPPOSED TO BE..
Aircooled or nothin....
Tobesetc
PostPosted: Wed Nov 21, 2018 10:39 am    Post subject: Reply with quote
Citori - I hope you haven't posted a pic of a non-Becker stereo? That's a black-ball offence, you'll get tarred and feathered. I rather enjoyed it Wink
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Citori
PostPosted: Wed Nov 21, 2018 12:42 pm    Post subject: Reply with quote
This is very true.
Should have seen what happened after they found out I put the wiper widget in the wrong place. Surprised
1996 C2 Coupe.
1981 911SC Sport.
1978 911SC.
1970 911E.
