997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 20
Cayenne : 2003- 4
Darren OD
PostPosted: Sun Oct 21, 2018 9:17 am    Post subject: Centre console lighting repair Reply with quote
Latest little job completed, none of the lights were working on the centre console, so a little digging revealed the pcb's with all the lamps failed. The lamps are not available as spares and the boards were £90 each which I thought was a rip off. This is my solution.
[img]
Before there are two like this, one above the hazard switch row, one above the spoiler and diff lock. I have used pre ballasted leds as these will work on 12v with no shunt resistor needed, the only thing to really look out for is the position on the tracks of the + and - so you can bend the legs of the resistor to the correct polarity.
[/img]
I used red on the top row and clear on the bottomwith red on the diff switch
[img]
Finished article[/img]
Mr Bacchus
PostPosted: Mon Dec 03, 2018 12:15 pm    Post subject: Reply with quote
Nice job.
I made a similar repair using the kit from Bergvill F/X, cheap as chips and comes with instructions.
Unfortunately my car has lost the template that forms the red symbols in your picture so my car looks like a red light district at night.
In vino veritas
MY89 964 C4 Guards Red, MY16 Evoque Coupe
