997 : 2004- 74
Boxster : 1997- 14
Luke997
PostPosted: Thu Oct 11, 2018 8:32 pm    Post subject: Dash rattle (not clocks) Reply with quote
Help please!
I’ve done a trawl through all the rattle threads. I have a rattle in my 997 dash which isn’t the clocks - I followed the service bulletin and even drove with the clocks out of the dash, I have an annoying rattle coming from within the dash area from behind the clocks. It’s driving me mad. Can anyone help? Could it be the CD changer cable or something like that? Thankyou
Richtw
PostPosted: Thu Oct 11, 2018 8:44 pm    Post subject: Reply with quote
I am a master at noise - it’s my ocd!! What sort of noise is it - a hard rattle, a buzz, metallic clank? Also is it speed dependant, Rev dependant? Have you checked to make sure the battery is secure? Have you turned off the air on to eliminate that? Might sound obvious but I am sure someone will have had something similar with a bit more description!!
Luke997
PostPosted: Thu Oct 11, 2018 9:05 pm    Post subject: Reply with quote
It’s literally a wire-on plastic like ticking noise. Independent of revs and triggered by bumps in the road surface. Battery is all secure, haven’t tried switching the air con off.
askgeez
PostPosted: Fri Oct 12, 2018 8:56 am    Post subject: Reply with quote
The grill between sport chrono clock and windscreen seems to be my rattle.
If I press it down , rattle goes away Dont know
One of these days I’ll work out how to secure it puh
997.2 GT3 coupe Manual (03/19 >)
911 SC Targa Manual (04/19 >)
997.2 GTS coupe PDK (06/17-02/19)
997.1 C4s coupe Manual (04/15-06/17)
Richtw
PostPosted: Fri Oct 12, 2018 9:10 am    Post subject: Reply with quote
Does it go away if you press down on the dash - may need someone in the car to help with this one!
PostPosted: Fri Oct 12, 2018 9:40 am    Post subject: Reply with quote
Rattles in the cabin front I have found are the central heating vents and the tiptronic metal top the spring under it .
hedgehogsdad
PostPosted: Fri Oct 12, 2018 9:55 am    Post subject: Reply with quote
I reckon my tiptronic cover is rattling, my continual rattle seemed to stop last weekend when I held the cover down. Is there a proven fix for this?
2006 997 Turbo
2003 996 Turbo
2006 Cayenne
1999 996 C2
1990 964 C2 Targa
1980 SC
Luke997
PostPosted: Sun Oct 14, 2018 1:09 pm    Post subject: Reply with quote
Thanks all, mines a manual gearbox, would this still be an Issue? Worth removing the dash to get to it?
PostPosted: Sun Oct 14, 2018 5:06 pm    Post subject: Reply with quote
Buzzing noise...
Ignition starter switch
Buzzing noises can be heard
while driving due to the reset
spring in the ignition starter
switch.
Creaking or clicking noise
A-pillar
Relative movements and direct
contact between the hinge
pillar and upper front wheel
Rattling noise
Glove box
Rattling noises can be heard
while driving due to tolerances
between the release bar and
receiver.
Rattling noises
CD box in glove box
Rattling noises can come from
this area as a result of
tolerances between the CD
box and glove box.
Creaking noise
Trim panel under dashboard
Creaking noises can be
caused by relative movements
between the centring journals
of the trim panel under the
dashboard and the dashboard.
Rattling or buzzing noise
Instrument cluster
Rattling or buzzing noises can
come from around the
instrument cluster caused by
dashboard inset and
instrument cluster.
PCM/air-conditioning system
regulator/centre console
Relative movements between
the PCM, air-conditioning
system regulator and the basic
centre console carrier at the
front can cause creaking or
clicking noises while driving.
 Filesize:  265.79 KB
 Viewed:  661 Time(s)
rob_p
PostPosted: Sun Oct 14, 2018 6:16 pm    Post subject: Reply with quote
I have a buzz which is rev and road surface dependent which I have tacked down to the trim surrounding the gear lever (manual). Try pushing the trim in front of the gear shift down while driving.
It's a long shot but you never know....
991.1 C2 (no mods, yet)
Jeep Grand Cherokee WK2
Ex Porsche Boxster 986
Ex Mazda MX5 mk1
