996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Grey996
PostPosted: Wed Oct 10, 2018 4:37 pm    Post subject: Help getting the rear control arm bolt out please Reply with quote
It’s the adjustable geometry bolt that must be corroded into the bush sleeve. With a breaker bar and lots of force I can turn it halve a turn then back again but it’s not yielding. The impact driver hasn’t made any in roads either. I’d just cut it off but I can’t a disc for in anywhere and I don’t think I could get any heat to the parts I need to?
Any ideas appreciated.
Simon
2002 Porsche 996 C2
 Filesize:  1.96 MB
 Viewed:  992 Time(s)
Ghianightmare
PostPosted: Wed Oct 10, 2018 5:18 pm    Post subject: Reply with quote
I just did this last weekend. As I had to return the used arm to Hartech, I couldn’t damage it at all.
On the front end, I used a hack saw blade in one of those handle things. No idea what it was called. Use a new blade. I was careful to cut through the bush and bolt about 2mm in from the edge. It meant cutting through the rubber a bit and I did it slowly to ensure the cut was straight. It took 40 min to cut through as it is 26mm thick and I had 20mm of movement back and forth. I contemplated my entire life while doing it...
On the rear side I started the cut with the hack saw to get the cut in the right poistion and then I broke out my electric reciprocating saw and cut through it in 5 min. I didn’t use much pressure - I let the blade do the work. Too much pressure can break the blade and then you can damage the frame as the stubb bangs off everything.
Take your time and take solace from the fact you are not alone! Best of luck
2002 Seal Grey C4S
Ghianightmare
PostPosted: Wed Oct 10, 2018 5:26 pm    Post subject: Reply with quote
My track rod
2002 Seal Grey C4S
 Filesize:  171.17 KB
 Viewed:  960 Time(s)
Grey996
PostPosted: Wed Oct 10, 2018 5:44 pm    Post subject: Reply with quote
Thanks for the reply, I had thought about the hacksaw blade but was hoping they'd be a quicker way, oh well I might as well enjoy the me time 😆
Sadly I don't own a reciprocating saw but maybe this is a good excuse to buy one!
2002 Porsche 996 C2
Stotty
PostPosted: Wed Oct 10, 2018 5:48 pm    Post subject: Reply with quote
My Indy had to cut both mine off when I had them replaced a couple of years back. It’s a bitch of a job.
Good luck!
2000 996, C2, manual, arctic/metropole, Koni shocks, H&R -30 springs, H&R ARB's, Rennline SS engine mounts, cup wheel, 170k miles. 2018 Touareg RLine Plus
911munKy
PostPosted: Thu Oct 11, 2018 1:00 pm    Post subject: Reply with quote
Get the best blade available, several of them, in a hacksaw holder thingy.
It took me 20 mins constant sawing each side of the bolt, when you are nearly through save a few mins of grind by turning the bolt and it will shear.
Be very careful not to cut through the mounting!!
Allow 1 hour per side constant work for replacement once you have it on jacks and wheels off.
Don’t forget that you’ll need a geo afterwards.
2000 C2 996
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu Oct 11, 2018 5:22 pm    Post subject: Reply with quote
You could try drilling through the arm and bolt together
Grey996
PostPosted: Fri Oct 12, 2018 7:55 pm    Post subject: Reply with quote
Thanks all, a friend has a reciprocating saw which I'm going to borrow.
2002 Porsche 996 C2
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Oct 12, 2018 7:59 pm    Post subject: Reply with quote
It is a pig of a job, I have done it twice and neither time was fun. Plenty of anti-seize on the new bolts when they go in.
maldren
PostPosted: Sat Oct 13, 2018 8:43 am    Post subject: Reply with quote
Centre Gravity did mine earlier this year and they came out fine (lucky me), they put them back with lots of aluminium grease which they used liberally on any parts that might stick in future.
Mike
