996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
millsv8
PostPosted: Tue Oct 09, 2018 8:11 am    Post subject: Spyder performance coffin arms! Reply with quote
Has anybody noticed that the inner bush hole on the coffin arms from spyder performance arm a full 1mm bigger in diameter!
I noticed when trying to fit polybush bushes and where loose.
Had a chat with supplier and was told that I need powerflex,I tried to explain that they are all designed for a 40.8mm hole not 41.8 but didn't believe me!
Good quality item but be aware not suitable for standard size poly or oe inner bushes.
I'm now making oversized ones so I can use.
