964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
MarkGolf
PostPosted: Sat Oct 06, 2018 12:52 pm    Post subject: Boxster 986 O2 sensor wiring? Reply with quote
Hi All,
I’m trying to track an issue with a dead signal (0.4v)from bank2 sensor 1 o2 sensor. I get a flat line, I managed to connect the bank2 sensor1 wire into the post cat o2 sensor (which is working and showing activity) and still got nothing, so I’m going to assume I’ve got a problem with the wiring on the car side. All o2 sensors are new.
It’s pissing down so I’ve come in for the minute but the wire for bank2sensor1 just disappears up the side of the engine, I was hoping to find the other end of it to check that it’s plugged in and all ok..
Any help appreciated (demort Wink )
Cheers!
Current fleet
My 964
My 997
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sat Oct 06, 2018 2:08 pm    Post subject: Reply with quote
If you trace the pin on the DME you can continuity check to the connector and this will tell you if you have a break in the wiring
PostPosted: Sat Oct 06, 2018 4:19 pm    Post subject: Reply with quote
Pm sent with diagram youll need .
MarkGolf
PostPosted: Sun Oct 07, 2018 7:42 pm    Post subject: Reply with quote
All sorted, will update my thread.
Thanks guys, Demort educated and supplied me with all the info to get this sorted once and for all Smile
Broken wire!
Current fleet
My 964
My 997
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
