996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Kith
PostPosted: Wed Oct 10, 2018 4:54 pm    Post subject: Reply with quote
DJP997 wrote:
Phil 997 wrote:
c4kum wrote:
Ok, you seem to already have the y cable, the usb cable on the Y cable needs to be plugged into the usb socket, all you then need is a Bovee 1000 30pin device, that’s is and stream until your heart is content.
Yeah Yeah Yeah Agree Thumb stream bluetooth , theres other ways to do it that will mean pluging the phone in every time for a hard wire link, but the Bovee is a tested way to bluetooth. Theres also an option from Visio as I am sure there will be others but we know the Bovee works and also interfaces giving you album title etc on the PCM which other options may not do. Thumb
Received Bovee today, all works as suggested, thanks guys.
Do you leave the Bovee plugged in overnight etc? I assume it is not powered but wanted to check it doesn't cause any issues....
Can you select playlists / tracks via the PCM screen with this?
997.2 Carrera 3.6 manual
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Wed Oct 10, 2018 6:51 pm    Post subject: Reply with quote
davenice wrote:
James M-S wrote:
I use a 64GB thumb drive in mine. Just takes a while to read all the tracks.
Does the PCM play all .mp3 files on your thumb drive? When I tried to use a 32Gb FAT formatted drive, I found that roughly half of my tracks got skipped over. Could have something to do with the encoding of the files but I couldn’t work out a pattern.
I have no idea to be honest. (Can’t remember exactly what is on the drive) My 32GB Drive performs better (in terms of time to load tracks and start playing)
mkoenigsheim
PostPosted: Thu Oct 11, 2018 8:21 am    Post subject: Reply with quote
Can you select playlists / tracks via the PCM screen with this?[/quote]
Blimey - if I recall(moved to Android 2 years ago) yes if you use Apple Music.
But android device or Spotify/other provider i don't think so...
DJP997
PostPosted: Thu Oct 11, 2018 12:45 pm    Post subject: Reply with quote
I am using Deezer - and yes i can thumbsup
Rr1
PostPosted: Tue Nov 20, 2018 3:47 pm    Post subject: Reply with quote
i am in the same situation but dont have the 'Y' cable. do i need to order this from Porsche?
to confirm the set up is just the Y connector and then the Bovee??
James M-S
PostPosted: Tue Nov 20, 2018 5:41 pm    Post subject: Reply with quote
Yes, y-cable from OPC, it’s about £25. (Assuming you have the iPod interface ports in your armrest)
Bovee 1000 about £90 on amazon.
Rr1
PostPosted: Tue Nov 20, 2018 6:10 pm    Post subject: Reply with quote
Thanks, yes all three ports in the armrest
FZP
PostPosted: Tue Nov 20, 2018 6:22 pm    Post subject: Reply with quote
Is there a usb/ycable for non apple products?
Stephen603
PostPosted: Tue Nov 20, 2018 7:06 pm    Post subject: Reply with quote
I did a video on this Bovee thing a while back
https://www.youtube.com/watch?v=VLiZz57pABY
Check it out Thumb
Check out my youtube channel
https://www.youtube.com/channel/UCCCdThonj4sHCOK2LtspS3w
Rr1
PostPosted: Tue Nov 20, 2018 7:13 pm    Post subject: Reply with quote
Is there a part number of specific name for the Porsche audio cable for the 997.2?
Geezer 911
PostPosted: Tue Nov 20, 2018 8:09 pm    Post subject: Reply with quote
Rr1 wrote:
Mate call up design 911 in Brentwood. My y cable broke 3 months ago and they had several in stock.
Rr1
PostPosted: Tue Nov 20, 2018 8:12 pm    Post subject: Reply with quote
thanks will do, 15% sale at the moment as well!
i doesnt seem to be on their website as only ones for the PCM2 are on there so will give them a ring
cheers
James M-S
PostPosted: Tue Nov 20, 2018 10:52 pm    Post subject: Reply with quote
Rr1 wrote:
PCM 3 Y cable (PN 997-612-471-02)
Rr1
PostPosted: Tue Nov 20, 2018 11:14 pm    Post subject: Reply with quote
Rr1
PostPosted: Wed Nov 21, 2018 9:36 am    Post subject: Reply with quote
'Y' cable ordered from 911 design as Cambridge Porsche dont stock these
Bovee 1000 ordered from Amazon
thanks for the help guys
GlenB
PostPosted: Thu Nov 22, 2018 9:35 am    Post subject: Reply with quote
Will the Bovee allow Android phone Bluetooth phone connection to the head unit too?
I ask because my PCM works strangely with my phone when connected. As in the text messages and phone logs get imbedded in the radio and do not show up on my phone, it also seems to disable all 4G and wifi when connected to the car. Drives me potty and could do with an alternative.
Rr1
PostPosted: Thu Nov 22, 2018 3:33 pm    Post subject: Reply with quote
Received the Bovee and Y cable but can’t play music from amazon or anything online because as soon as I plug it in it takes away the 4G from the phone???
Stephen603
PostPosted: Thu Nov 22, 2018 5:50 pm    Post subject: Reply with quote
At least for the iPhone this works once you get phone calls a prompt appears on how you wish to take the call through bovee or the pcm or just via the headset. Your phone should be able to connect to multiple Bluetooth devices at the same time. One Is the PCM and the other is Bovee.
James M-S
PostPosted: Thu Nov 22, 2018 9:00 pm    Post subject: Reply with quote
So the y cable is attached in the armrest, circular connector for audio signal, usb for power, 30 pin Apple connector attached to bovee.
You should get blue led on bovee indicating it is powered.
I assume your phone is paired to bovee (instructions in bovee box).
Has your phone connected to bovee? My iPhone 6 shows headphones icon.
Turn up volume on phone
Set your pcm source to aux or ipod.
Play your music source
You should now be good to go. From amazon/Spotify/YouTube etc.
I can’t understand why you lose mobile 4g coverage.
If you have done all the above, pull out the y-cable and check you haven’t snapped a pin in the round connector. I did that in my enthusiasm the first time as it’s a bit fiddly.
Rr1
PostPosted: Thu Nov 22, 2018 9:20 pm    Post subject: Reply with quote
Yes, all connected up correctly and Bluetooth connection fine.i can play the music but it is knocking the 3G/4G as soon as I plug it in so any steamed music isn’t possible. Very weird....not sure why or how it is effecting the internet?
I have the new iPhone XR which is all up to date
Page 2 of 3
